turning piston diameter down #2465449
03/12/18 10:00 PM
03/12/18 10:00 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
A friend of mine has a set of JE gas ported pistons that are .060 0ver .They have lite scratches on the skirts. He's going to toss them. Could they be turned down to a .030 over size? and if so at what cost.
Re: turning piston diameter down [Re: rowin4] #2465469
03/12/18 10:20 PM
03/12/18 10:20 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Is it possible to clean them up at .055" over?
Brian
Re: turning piston diameter down [Re: rowin4] #2465473
03/12/18 10:22 PM
03/12/18 10:22 PM
Minn
SportF Offline
SportF  Offline
Minn
Pistons are not round top to bottom. AND, there is different diameters, so to speak, at the egg shape. As such, it is not a one cut deal on a lathe.
But, never machined a piston myself, may it is possible. Be interested to hear from real experience.
Re: turning piston diameter down [Re: rowin4] #2465491
03/12/18 10:38 PM
03/12/18 10:38 PM
rowin4 Offline OP
rowin4  Offline OP
I'm sure they would clean up at .055 .I just never heard of it being done or how the piston would beheld to do the turning.
Re: turning piston diameter down [Re: rowin4] #2465509
03/12/18 10:55 PM
03/12/18 10:55 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Years ago I had a set of .060 over oem pistons turned undersized so they would check legal for a NHRA stocker. It was done somewhere in Detroit, but the engine builder never revealed his source. Whoever did the job cam ground them to the same specs as TRW pistons. Going fast in a NHRA stocker was never cheap.
Re: turning piston diameter down [Re: rowin4] #2465628
03/13/18 03:23 AM
03/13/18 03:23 AM
I had a set of 9second Phils pistons hard anadised in SO CA to save them, he had a bad set of solid lifters that the tops started failing allowing pieces of them to get embedded into the forged Ross pistons skirts, they where 4.080 340 pistons and he didn't want to go to the next size bigger so we saved them by doing what we had done shruggy That company was a aerospace company and they won't do them anymore whiney that company made them exactly the same size as they where new, we could of had another .0010 to .0030 added onto the diameter of the skirts for no extra costs work
On your deal I wouldn't hesitate a second to look at some of the current coatings out there now to save them scope up
Don't take a chance on doing anything not proven, it ain't worth it to take a chance on any Hi Po motor parts tsk
Re: turning piston diameter down [Re: rowin4] #2465630
03/13/18 03:47 AM
03/13/18 03:47 AM
CA
62SAVOY Offline
62SAVOY  Offline
CA
Finish on piston has a lot to do with how they run also. We were shocked on our hi reving 2 strokes engines what a difference finer or coarser finish would do on power. We would make one in the cnc lathe and dyno an engine. Depending what the power was like we would change it and try again. We tried different finish on the turning getting better and also getting worse on our results. Once we found what we like we ran all of our pistons this way. That is one advantage of having everything in house.
Re: turning piston diameter down [Re: rowin4] #2465633
03/13/18 04:33 AM
03/13/18 04:33 AM
Another thing to keep in mind is that the two different alloys will look a lot different on the skirts, the tight alloy look a lot worse after use than the looser alloys do with the same abuse work
My message is to measure them to see if there hurt or not scope
Don't always trust your eyeballs when it comes to judging race parts tsk Check them out thoroughly first before making any decisions on race parts, just like you should on women whistling grin whistling
Re: turning piston diameter down [Re: rowin4] #2465664
03/13/18 10:20 AM
03/13/18 10:20 AM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
Got a pic of the worst one?
Re: turning piston diameter down [Re: LSP] #2465929
03/13/18 06:43 PM
03/13/18 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If they are just lightly scuffed I'd use them..
I have used some fairly ruff ones.. just use
a stone on them.. you will be surprised.. I have
had 1 set coated and they are still working well
on a street engine
wave
Re: turning piston diameter down [Re: rowin4] #2465949
03/13/18 07:10 PM
03/13/18 07:10 PM
NY usa
540challenger Offline
NY usa
If the skirts are the only thing wrong why not just get the skirts coated???
Re: turning piston diameter down [Re: rowin4] #2466021
03/13/18 09:02 PM
03/13/18 09:02 PM
rowin4 Offline OP
rowin4  Offline OP
How much does the coating add in thickness?
Re: turning piston diameter down [Re: rowin4] #2466023
03/13/18 09:08 PM
03/13/18 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had .004 added to a set.. they can add more
wave
Re: turning piston diameter down [Re: rowin4] #2466087
03/13/18 11:02 PM
03/13/18 11:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would say all if not all NASCAR engine builders turn their own pistons.
Re: turning piston diameter down [Re: rowin4] #2466172
03/14/18 01:35 AM
03/14/18 01:35 AM
rowin4 Offline OP
rowin4  Offline OP
I talked to a engine builder and had him look at them, he said he'd run them as is . This of coarse changed my game plan of getting a free set of $800. pistons as the owner of them was there also. Now he's peed as he bough a new set on advice of another builder.
Re: turning piston diameter down [Re: rowin4] #2466206
03/14/18 03:02 AM
03/14/18 03:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Make him a offer of a little less than 40% and
see what happens(this based on how they look)
wave
Re: turning piston diameter down [Re: cudaman1969] #2466780
03/15/18 07:04 AM
03/15/18 07:04 AM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
No, the only team turning any pistons is Hendrick.
Re: turning piston diameter down [Re: rowin4] #2468415
03/19/18 12:43 AM
03/19/18 12:43 AM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
Fellaz, what about the ring fitment. Won't the inside diameter of the ring pinch the piston inner groove?
Dakota for life!
Re: turning piston diameter down [Re: Scojodak] #2468431
03/19/18 01:42 AM
03/19/18 01:42 AM
Only if you don't check the back clearances properly scope
I shoot for .005 minimum with the rings pushed all the way into the ring lands, 1st,2nd and 3rd rings scope wrench up
If it has more than .025 it is time for ring spacers up
Re: turning piston diameter down [Re: MR_P_BODY] #2468434
03/19/18 01:45 AM
03/19/18 01:45 AM
rowin4 Offline OP
rowin4  Offline OP
wave
I talked to him last Wednesday and he said after he thought about what the engine guy said about still being usable , he said he was going to keep them. I'll bring it up once in awhile as he probably won;t ever use them as his block is bored to the next oversize.
