70-74 Barracuda hood pin center to center distance #2465415
03/12/18 09:20 PM
03/12/18 09:20 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Can I ask a favor? I need the dimension for the center to center spacing on the hood pins of a Barracuda (not a Challenger). Don't need to split atoms but +/- 1/16" would be great.
Jim Fillmore
Detroit Muscle Technologies
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 70-74 Barracuda hood pin center to center distance [Re: 71TA] #2465422
03/12/18 09:27 PM
03/12/18 09:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Jim Fillmore
71 Cuda 43 3/4" center to center
Mike
Re: 70-74 Barracuda hood pin center to center distance [Re: DAYCLONA] #2465487
03/12/18 10:36 PM
03/12/18 10:36 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I just measured my original AAR hood that's sitting in my office and it's 43" on the nose.
Re: 70-74 Barracuda hood pin center to center distance [Re: 71TA] #2465500
03/12/18 10:44 PM
03/12/18 10:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The under hood skins have holes for the pins, so the hoods themselves should be measured.
Mounting brackets / pins can be bent, tweaked etc. but the pin holes should be centered via the larger under skin holes in the hoods.
Re: 70-74 Barracuda hood pin center to center distance [Re: 71TA] #2465552
03/12/18 11:57 PM
03/12/18 11:57 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks guys.
Jim Fillmore
Re: 70-74 Barracuda hood pin center to center distance [Re: Alaskan_TA] #2465640
03/13/18 06:54 AM
03/13/18 06:54 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I easily could have given you an under hood skin education Jim, I'm so so sorry for giving you exactly what you asked for.
Re: 70-74 Barracuda hood pin center to center distance [Re: HEMICUDA] #2465680
03/13/18 11:33 AM
03/13/18 11:33 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Interesting?,...I measured the center to center of the pins as requested 43 3/4 center to center, I then measured the same car's hood's holes, (71 Cuda shaker) 43 7/8" across the top of the hood, center to center
I have 2 other Shaker hoods, same measurement ....plus a Cuda Sport hood that measured 43 5/8" center to center across the top of the hood's holes ...I have a Challenger T/A but that's a moot point for measurement,...
So the question is?, is an AAR's pin hole (43" CTC) spacing different? or is this a case of badly placed holes seeing the unique build of T/A cars? ...inquiring minds would like to know?
FWIW: the holes center to center measure the same top or bottom...
Mike
Re: 70-74 Barracuda hood pin center to center distance [Re: DAYCLONA] #2466199
03/14/18 02:43 AM
03/14/18 02:43 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I'm sure it is a quality issue with the glass hood Mike. I am to lazy to check all the hoods I have in my storage container.
