Cable style throttle bodies, what are my options? #2464451
03/10/18 08:15 PM
03/10/18 08:15 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Will be running an ms3 gold box and need to switch to a cable operated tb... used one meqasquirt listed on their site for the last one, but don't see them available now. I know bbk has them, but kind of pricey. What other options are there, direct fit or with adapter.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2464461
03/10/18 09:03 PM
03/10/18 09:03 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I use a FAST Big Mouth 87mm throttle body part# 54089. It uses GM sensors though.
I also use an MS3 gold box and Mike converted my sensors to GM ones
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2464529
03/11/18 12:22 AM
03/11/18 12:22 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My new #1791 BBK works fine and was only $165.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Cable style throttle bodies, what are my options? [Re: GoodysGotaCuda] #2464657
03/11/18 11:54 AM
03/11/18 11:54 AM
Colorado
MoparCar Offline
MoparCar  Offline
Colorado
Where were you able to find this at this low of price? Special sale? Everywhere I look its between $340-$380.
Thanks-
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2464833
03/11/18 05:39 PM
03/11/18 05:39 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
They are about 360... was looking to see if there are other options, not a price on something I already know about.
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2464978
03/11/18 11:00 PM
03/11/18 11:00 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
maybe consider an LS swap if bolt-on Hemi parts are too expensive. That plus the junkyard trans would be perfect. drive
2020 RAM 1500
Re: Cable style throttle bodies, what are my options? [Re: MoparCar] #2464990
03/11/18 11:20 PM
03/11/18 11:20 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks-
Slow moving items on Amazon sometimes end up with low pricing until one gets bought.
2020 RAM 1500
Re: Cable style throttle bodies, what are my options? [Re: GoodysGotaCuda] #2465095
03/12/18 09:22 AM
03/12/18 09:22 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Thanks-
+1
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2465352
03/12/18 07:03 PM
03/12/18 07:03 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I found a way to convert the stock tb to cable drive for cheap... works for me.
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2465396
03/12/18 08:40 PM
03/12/18 08:40 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
No IAC? frog
2020 RAM 1500
Re: Cable style throttle bodies, what are my options? [Re: GoodysGotaCuda] #2465416
03/12/18 09:20 PM
03/12/18 09:20 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
No IAC? frog
Considering they don't have one to being with, nope, not adding one. laugh2
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2465451
03/12/18 10:00 PM
03/12/18 10:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Goodysgotapoint, how do you plan to control idle speed?
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2465452
03/12/18 10:04 PM
03/12/18 10:04 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
The same way as on a carb... with a stop/adjuster. Summer car that won't be driven in cold weather, not much of an issue.
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2465518
03/12/18 11:07 PM
03/12/18 11:07 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Have fun, IACs aren't cheap anyway.
2020 RAM 1500
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2466036
03/13/18 09:34 PM
03/13/18 09:34 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Use the comp cams adapter (~$60) then any LS throttle body you want. Setting up the GM TPS and IAC is pretty straightforward on the MS based system.
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2470308
03/22/18 12:09 PM
03/22/18 12:09 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Pick up a used Viper one.
Cable was used until 07 IIRC.
Matt
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2470950
03/23/18 02:05 PM
03/23/18 02:05 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
EFIsource sells an adapter to use ls style tb's and the harness can be ordered to use them also. Adapter is around 50.
Looks like the issue with the viper one is they ran twin tb's and you'd have to use a left side tb to attach the cable, but then linkage goes to the right side and that's the one with the tps sensor.
Re: Cable style throttle bodies, what are my options? [Re: GoodysGotaCuda] #2472722
03/27/18 01:21 PM
03/27/18 01:21 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Thanks-
I bought spectra fi cuda tank for 114 shipped from amazon... Guess I need to check there more often. I noticed they have another, started aroun 350 and down to 260 now in a couple days.
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2473038
03/27/18 11:14 PM
03/27/18 11:14 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks-
...or...
http://camelcamelcamel.com [yes, it's a legit website]
2020 RAM 1500
Re: Cable style throttle bodies, what are my options? [Re: Silver70] #2473369
03/28/18 03:59 PM
03/28/18 03:59 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Thanks-
Funny you mentioned the crazy deal on the Spectra FI Tank.
Just the other day I just picked up an E-body, Spectra FI pump/sender SUPER CHEAP on Amazon too. Too cheap to pass up.
If you need it for your tank, let me know.
1972 Swinger 3.6L Pentastar
Diablo CMR tuner
