cast crank 440, new pistons...balance?
#2465135
03/12/18 11:15 AM
03/12/18 11:15 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Say you had a low compression cast crank ext. balance 440 you were putting in a bracket car. You want to put some decent flattops in it so it had more compression. Keeping the stock rods. Would you need to stay w/ a heavy Speed Pro "Six Pack" piston or could you use (what I'm assuming is slightly lighter) Wiseco Pro True Street piston?
Anyone know a ball park weight of a stock slug vs. either of these two options? How much lighter before it HAS to be balanced?
I usually balance all my stuff w/o question, but this is a real budget buildup.
Re: cast crank 440, new pistons...balance?
[Re: an8sec70cuda]
#2465182
03/12/18 01:13 PM
03/12/18 01:13 PM
an8sec70cuda
Thanks EV2! I've found the "six pack" pistons are very close to the stock 440 piston weight at around 870 grams. Haven't been able to find a weight on the Wisecos yet. This is a "beginner" engine for a friend of mine's son who wants to get started in racing. Just a hydraulic cammed 440 w/ a set of home ported cast iron heads, Holley SD intake, 830 holley, etc. Going in a fairly light (gutted) Dakota truck. If it was mine, I'd probably just re-ring it and use the stock pistons since the motor runs great like it is now in bone stock form.
Later down the road when he gets some experience, they'll likely stroke it and get some good heads for it.
[Re: an8sec70cuda]
#2465184
03/12/18 01:25 PM
03/12/18 01:25 PM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
I got a set of the Speed Pro in one of my 440's, ran it with stock rods and didn't balance it. It was with a forged crank, not sure if that makes a difference. Didn't seem to hurt anything and ran okay (shifted at 6000, didn't turn over 6200)
I was researching the Weisco pistons awhile back and didn't have any luck finding weights on them, but did email Hughes about P/N:PTS531A3 and they said they weight Piston 546.50, Pin 220.39.
[Re: an8sec70cuda]
#2465187
03/12/18 01:30 PM
03/12/18 01:30 PM
an8sec70cuda
DusterKid...thanks! Sounds like the Wisecos are gonna be too light to not balance it.
