Auto Stop/Start #2464350
03/10/18 05:04 PM
03/10/18 05:04 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
New Jeep has auto stop/start, has anybody figured out a way to disable this permanently?
Re: Auto Stop/Start [Re: 71birdJ68] #2464352
03/10/18 05:11 PM
03/10/18 05:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
My wife's Cherokee has a button on the dash marked A that shuts it off but she has to hit it every time she starts the car. One thing to know about the s/s is if it starts showing a notice on the instrument cluster that it can't work because the battery is charging it's time to replace the battery. Also your fuel milage will drop about a mile per gallon when the battery starts to go bad because the charging system works all full blast all the time. Her factory battery lasted a little over two years.
Re: Auto Stop/Start [Re: 71birdJ68] #2464360
03/10/18 05:25 PM
03/10/18 05:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I found this on a jeep site. http://jeepgarage.org/f156/solution-to-disable-auto-start-stop-185234.html
Guy on the same site is selling a plug in that disables it for $125.
Re: Auto Stop/Start [Re: 71birdJ68] #2464643
03/11/18 11:25 AM
03/11/18 11:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Unplug the plunger style hood switch.
Doug
Re: Auto Stop/Start [Re: 71birdJ68] #2464770
03/11/18 03:08 PM
03/11/18 03:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Problem with unplugging the hood switch is that it may disable emergency equipment like the air bags etc. because it makes the computer think the hood is open.
Re: Auto Stop/Start [Re: 71birdJ68] #2464781
03/11/18 03:34 PM
03/11/18 03:34 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree my sons has an off switch on the dash.Look in the Owners manual it should show one.Rocky
Chrysler Firepower
Re: Auto Stop/Start [Re: therocks] #2464865
03/11/18 07:07 PM
03/11/18 07:07 PM
Morristown Tn.
Morristown Tn.
This is a Compass, I found the hood switch, but not going to unhook unless I know it won't affect anything else. I emailed the guy that has the plug in thing, but it is just for Grand C, so, waiting to see if he has something for the Compass.
Re: Auto Stop/Start [Re: 71birdJ68] #2464879
03/11/18 07:38 PM
03/11/18 07:38 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
If it has remote start, that function will no longer work if it thinks the hood is open.
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Auto Stop/Start [Re: 71birdJ68] #2464906
03/11/18 08:38 PM
03/11/18 08:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
... http://www.smartstopstart.com/
Re: Auto Stop/Start [Re: DAYCLONA] #2464928
03/11/18 09:08 PM
03/11/18 09:08 PM
Morristown Tn.
Morristown Tn.
I just got an email from them, nothing for the Compass, but he said they were hoping to make one for it. Thanks
Re: Auto Stop/Start [Re: 71birdJ68] #2464965
03/11/18 10:32 PM
03/11/18 10:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you disconnect the hood latch switch the remote start will not work but if you disconnect the plunger hood switch it will work but you are back into the who knows what else won't work stage.
Re: Auto Stop/Start [Re: 71birdJ68] #2464972
03/11/18 10:54 PM
03/11/18 10:54 PM
A727Tflite Online content
A727Tflite  Online Content
Call 1-800-992-1997 - FCA National Customer Service and ask them. They may be able to help.
Re: Auto Stop/Start [Re: 71birdJ68] #2465000
03/11/18 11:29 PM
03/11/18 11:29 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Will the wipers work correctly if the hood switch is disabled?
When I had a hiccup with the hood switch on my Mercedes the wipers didn't function properly. The'd only work with the car at speed and the wiper speed was not adjustable.
- Stu Harmon
Re: Auto Stop/Start [Re: feets] #2465030
03/12/18 12:23 AM
03/12/18 12:23 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Security systems will be disabled as well on most systems with a hood switch. I would not be concerned with the safety systems like airbags or any other SRS belt functions because most of those systems are on a separate buss.
I would think that a simple push of a button when you start the car wouldn't be that unreasonable shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Auto Stop/Start [Re: fourgearsavoy] #2465038
03/12/18 12:37 AM
03/12/18 12:37 AM
Morristown Tn.
Morristown Tn.
Every time you get in your car, start the engine, and then you have to push another button, every single time you drive. It gets old. Oh, and another stupid part of the function, when you pull in to a parking spot, the engine dies, and then when you put it in park, the engine starts up again. The starter, and battery have to be over worked with stuff.
Re: Auto Stop/Start [Re: 71birdJ68] #2465097
03/12/18 09:33 AM
03/12/18 09:33 AM
West Virginia
N
NewbombTurkk Offline
N
West Virginia
Another reason I stick to pre-2005 Grand Cherokees with the 4.0.....simple and no touch screens or fancy electronics stuff. I would like side airbags though.
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD
Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
Re: Auto Stop/Start [Re: 71birdJ68] #2465099
03/12/18 09:37 AM
03/12/18 09:37 AM
P
Porter67 Offline
Porter67  Offline
P
Why even buy that make model if its that much of a issue to you?
Re: Auto Stop/Start [Re: 71birdJ68] #2465107
03/12/18 10:01 AM
03/12/18 10:01 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My sons Jeep once you turn the auto start off its off till you push the button to reengage it.Rocky
Chrysler Firepower
Re: Auto Stop/Start [Re: 71birdJ68] #2465146
03/12/18 11:59 AM
03/12/18 11:59 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Is it that irradiating? My wife drives a Toyota Highlander Hybrid. The gas engine is turning on and off all the time and I don't even notice anymore.
Re: Auto Stop/Start [Re: Porter67] #2465166
03/12/18 12:30 PM
03/12/18 12:30 PM
Morristown Tn.
Morristown Tn.
Why did I buy it? I never even heard of stop/start until we bought this Jeep. It's not on all of them, it is part of some optional package.
