Re: Steel lower rad hose, Big Block
[Re: terzmo]
#2464533
03/11/18 12:33 AM
03/11/18 12:33 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Is there a chance that this might be a carb tuning issue when the primary circuit transitions in?
I recently asked a local parts store why the newer lower hoses did not come with a wire. They said that the manufacturers are using better rubber materials that no longer require the wire insert which prevents collapse. How old is your lower hose?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: terzmo]
#2464566
03/11/18 02:36 AM
03/11/18 02:36 AM
RapidRobert
You may need more radiator
[Re: terzmo]
#2464588
03/11/18 03:48 AM
03/11/18 03:48 AM
Posts: 954 Chicago
PurpleBeeper
Chicago
Overheating at highway speed is a sign that you're either not getting enough air flow...like electric fans blocking the radiator...or the radiator is too small. Another possibility is that someone accidentally used 100% antifreeze instead of 50/50
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2464601
03/11/18 04:22 AM
03/11/18 04:22 AM
Posts: 17,515 Las Vegas, NV
6bblgt
Las Vegas, NV
I believe a couple responses are taken out of order the coil spring inside the lower hose is an aid on the assembly line where the cooling system is filled under vacuum & if your cooling system is developing proper pressure, the hose is not going to collapse
[Re: terzmo]
#2464606
03/11/18 04:49 AM
03/11/18 04:49 AM
Andrewh
you do not mention what fan or shroud you are using. I agree, if it can keep up in town, air restrictions are hurting you on the freeway. The fact it is coming back down at 55 tells me you have enough radiator and it is spending enough time there. Something is blocking air flow. It might still be possible that your lower hose is collapsing, and you could test that by staying in a lower gear at 55 so your rpm is higher. if it starts creeping up, then I would use the steel hose with the rubber ends. http://www.jegs.com/i/JEGS/555/511241/10...DYaAl-yEALw_wcB
[Re: terzmo]
#2464850
03/11/18 06:32 PM
03/11/18 06:32 PM
RapidRobert
You might be able to coil a welding rod in the hose to confirm/elim that potential without any expenditure. Post what it ends up being. EDIT with more thought, you could (in your driveway) run it up to the RPM that it is acting up at on the highway & see if the hose starts to suck shut. water flow is the same at a given RPM so it it is doing it at speed it will do it in your driveway at rest. this will quickly resolve that potential.
[Re: BigBlockMopar]
#2464969
03/11/18 10:38 PM
03/11/18 10:38 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
The shroud could actually act as a limiter when too much air tries to enter through the radiator. Some shrouds have rubber flaps that open up when enough airflow is there.
Also most likely that underhood air can't escape the engine bay fast enough causing lower airflow through the radiator and engine heat is building up.
A front spoiler can create some lower pressure behind it which could in turn help evacuate hot underhood air and aid overal cooling. I don't see the shroud as suggested is an issue at high speed
[Re: ns1aar]
#2465154
03/12/18 12:11 PM
03/12/18 12:11 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Performance, car would run fine until up to 65-70MPH and the temp would climb but ran fine at slower speeds. Head gaskets were bad
NS1AAR
[Re: 6bblgt]
#2465424
03/12/18 09:33 PM
03/12/18 09:33 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
if you can't maintain temperature & it is exceeding your thermostat rating - the excellent flow & open thermostat may not allow the fluid to spend enough time in the radiator to cool so then, why when a car is running hot, do you " race" the engine, thereby speeding up flow? wouldn't you want it to idle, so the coolant spends more time in the radiator?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: terzmo]
#2465428
03/12/18 09:36 PM
03/12/18 09:36 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I have a 472 hemi in a 67 R/T that runs cool in hot weather in traffic and down the road for what I say are short high speed runs. At 65 to 70 mph the temp will rise over 200 (slowly) if kept at the speed. Slow to 50-55 and the temp will go down. Alum rad with stock waterpump. I'm thinking a problem "could" be the lower hose collapsing at higher RPM. Does anyone use a non stock rigid or flex metal lower hose ? what's your timing? what carb?
[Re: Spaceman Spiff]
#2465713
03/13/18 12:32 PM
03/13/18 12:32 PM
Posts: 19,355 north of coder
moparx
if you can't maintain temperature & it is exceeding your thermostat rating - the excellent flow & open thermostat may not allow the fluid to spend enough time in the radiator to cool so then, why when a car is running hot, do you " race" the engine, thereby speeding up flow? wouldn't you want it to idle, so the coolant spends more time in the radiator? see thread in the race section. "time in the radiator" is an old wives tale. you need coolant flow, air flow, plus adequate radiator size to maintain cooling parameters.
[Re: terzmo]
#2466704
03/15/18 12:28 AM
03/15/18 12:28 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Watching this thread as I have the same issues with our big blocks.
People saying YES thermostats 50%, people saying NO thermostat %15 and people saying cut the guts out of the stat %35 .
We have run with the guts cut out, too hot and just run without a thermostat and still too hot, trying the 180 thermostat soon even though some say it will not help.
1963 Plymouth Max Wedge 1971 Barracuda
#2467044
03/15/18 07:57 PM
03/15/18 07:57 PM
terzmo
Pendleton NY
I have a 472 hemi in a 67 R/T that runs cool in hot weather in traffic and down the road for what I say are short high speed runs. At 65 to 70 mph the temp will rise over 200 (slowly) if kept at the speed. Slow to 50-55 and the temp will go down. Alum rad with stock waterpump. I'm thinking a problem "could" be the lower hose collapsing at higher RPM. Does anyone use a non stock rigid or flex metal lower hose ? what's your timing? what carb? Holley 950 double pump 12 at idle..36 at high speed
[Re: terzmo]
#2467552
03/16/18 11:07 PM
03/16/18 11:07 PM
ozymaxwedge
Australia
terzmo, Is your timing ALL in at 65mph ? Maybe it is not full advance at the RPM your sitting on ?
[Re: moparx]
#2468154
03/18/18 04:39 PM
03/18/18 04:39 PM
Posts: 1,211 Minn
SportF
Minn
if you can't maintain temperature & it is exceeding your thermostat rating - the excellent flow & open thermostat may not allow the fluid to spend enough time in the radiator to cool so then, why when a car is running hot, do you " race" the engine, thereby speeding up flow? wouldn't you want it to idle, so the coolant spends more time in the radiator? see thread in the race section. "time in the radiator" is an old wives tale. you need coolant flow, air flow, plus adequate radiator size to maintain cooling parameters. This is one of my 3 most favorite myths though. Neat thing about it is that it will NEVER go away.
