AO1 light package map light funtion #2463754
03/09/18 02:42 PM
03/09/18 02:42 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’m installing all new wiring in a 70 Challenger. The map light harness is all used but in very good condition. My AAR with this package, comes on when you open the door. You can flip the switch forwards and it comes on with doors closed. Is this correct? The Challenger I’m working on only comes on when the switch is in the rear position with the doors open. I’ve crawled under the dash and everything is plugged into the correct spot on the harness. I can’t get it to come on with the doors closed. Have I missed something simple or is my AAR just a fluke. Thanks
Re: AO1 light package map light funtion [Re: fastmark] #2463766
03/09/18 03:05 PM
03/09/18 03:05 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Ok. Never mind. I figured it out. Two bad switches and some trial and error. Seams there are two circuits inside the switch. One is constant on, tied to the door switch and the other is grounded to the dash when you flip the switch forward. I have a poor ground.
Re: AO1 light package map light funtion [Re: fastmark] #2463862
03/09/18 05:40 PM
03/09/18 05:40 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Lucas systems may be called the "Prince of Darkness"
But Chrysler wrote the book on bad grounds!! scope
Glad you found the problem.
Thanks for reaching out to Moparts......
We have an "open circuit" policy,LOL!!! drumhit
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: AO1 light package map light funtion [Re: fastmark] #2464063
03/09/18 10:26 PM
03/09/18 10:26 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Actual, it’s was the switch itself with the bad ground. It’s pretty lame for a switch. Easy to fix though. Opened it up and cleaned, greased and bent the ears back in place and it works fine.
