Re: Portable Air Compressors [Re: RoadRunnerLuva] #2462478
03/07/18 11:20 AM
03/07/18 11:20 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I looked at the California models. Once I read "oil-less", I didn't have to read any more.
Re: Portable Air Compressors [Re: 6PakBee] #2462520
03/07/18 12:58 PM
03/07/18 12:58 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
That is what I thought also, but go to their website and watch a video comparison. Actually very quiet.
I don't know about pricing but it looks like good stuff.
Bill
Re: Portable Air Compressors [Re: RoadRunnerLuva] #2462569
03/07/18 02:19 PM
03/07/18 02:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
As I stated in my previous post my Chaftsman oil-less is quieter then most oil-less and it has lasted me a long time. No complaints here.
Re: Portable Air Compressors [Re: 6PakBee] #2462580
03/07/18 02:33 PM
03/07/18 02:33 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Time to embrace improved technology. The thing works as good for its size as my baldor 2 stage 80 gallon upright.
Re: Portable Air Compressors [Re: Leigh] #2462641
03/07/18 04:26 PM
03/07/18 04:26 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Teflon piston rings on a non-lubricated reciprocating compressor is nothing new. I was involved with the big IR NL series two stage recips nearly 40 years ago. They just do not have the longevity of a traditional oil lubricated reciprocating compressor. I will admit, if you are going to use a compressor one day a month any style will work for a while. For equivalent capacity I'll go with a traditional oil lubricated recip like my Industrial Air 5 Hp two stage any day of the week. But this is only my opinion and each is entitled to their own based on what their goals are for usage, price, and longevity.
Re: Portable Air Compressors [Re: RoadRunnerLuva] #2462770
03/07/18 08:32 PM
03/07/18 08:32 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I have a 10 gal Craftsman I bought back in 1985 that's still going. Nice thing about it is that it was originally made by Devilbiss, so I was able to throw a rebuild kit at it 'just because' after 15 years and it's still working fine after 30+ years, and will fit in my trailer alongside my bench for track side duty. At home I added another 10 gal tank to it by running the output from the 1st tank into the 2nd, to add additional volume for bead blasting, etc. It's my go to compressor at home unless I am doing lots of blasting, then I fire up the 220 v 60 gal Campbell Hausfeld.
Re: Portable Air Compressors [Re: RoadRunnerLuva] #2463597
03/09/18 10:11 AM
03/09/18 10:11 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
having owned a Craftsman stand up oil-less unit.... I'm glad I found someone to buy it. I would literally go in the house or step outside of the garage when it would kick on. What a miserable pos! Currently have an old style electric motor/belt compressor. quiet as can be.
Re: Portable Air Compressors [Re: J_BODY] #2463734
03/09/18 02:23 PM
03/09/18 02:23 PM
dogdays Offline
dogdays  Offline
For topping off tires, I use the Harbor Freight model that is sometimes on sale for $39.99. As much as I use it, there's no need for anything better. If it breaks, recycle it and buy a new one. It is, however, noisy as heck.
I also have a ProPower compressor that is oil lubed, another cheap Chinese compressor that I bought at Pep Boys. It worked great until I broke the pressure switch.
I'm surprised that there's been hardly any mention of the compressors that are used to drive nail guns. Here's an article to consider: https://mozaw.com/best-air-compressor-for-nail-guns/
The OP is not looking for a shop compressor. Portable means easy to move around. Nail gun compressors are by nature portable.
R.
Re: Portable Air Compressors [Re: J_BODY] #2463777
03/09/18 03:17 PM
03/09/18 03:17 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Not to belabor a point, but this is exactly the California Air Tools forte. You literally can stand beside it, and not have to raise your voice to talk.
Re: Portable Air Compressors [Re: dogdays] #2463789
03/09/18 03:32 PM
03/09/18 03:32 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By dogdays
...I'm surprised that there's been hardly any mention of the compressors that are used to drive nail guns. Here's an article to consider: https://mozaw.com/best-air-compressor-for-nail-guns/...
Unless I misunderstood him, the OP wanted a compressor in the 4-10 gallon range for car/truck/bike tires, and other basic needs. Those $50 pancake nail gun compressors aren't in that group. But if the OP scaled his expectations back, they would be a reasonable choice.
Re: Portable Air Compressors [Re: 6PakBee] #2463820
03/09/18 04:02 PM
03/09/18 04:02 PM
Land 'O Lakes
RoadRunnerLuva Offline OP
Land 'O Lakes
Yup...as I originally stated, not looking for a big "shop" compressor.
Just a portable basic unit for filling up tires, and other simple stuff.
I really don't want a loud/noisy unit, since I have a small 1-1/2 garage
with close neighbors on either side of me.... popcorn
Re: Portable Air Compressors [Re: RoadRunnerLuva] #2463832
03/09/18 04:26 PM
03/09/18 04:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not sure if this was talked about but ANY air "tool" needs volume to work. Pumping up tires, nail guns, things in that order will work with the small compressors. 80 gallon with an two cylinder two stage pump is entry level to run air wrench sand sand blasters, even then the smaller ones can't keep up. I have 4, from a tiny Senco, a 4 gallon Emglo, an 80 gal Emglo and the shop 80 gal (can't remember the name) that's 43 years old and will still pump up from empty to full (150) in 4-1/2 minutes. All have their uses. If buying used, those will be your best deals, go brand name only. Tanks, motor will all do but the compressor is the main item, don't skimp on it.
