Thermo Quad Floods Over Help #2461666
03/05/18 09:08 PM
03/05/18 09:08 PM
NE
moparpoolman Offline OP
NE
On a 72 400 my Thermo Quad floods over after the car is turned off. I just replaced the needle and seats and made sure the floats were at the right adjustment. Started it up, ran great, ran it for a while, got it up to temp, turned it off and in about a minute it starts flooding over again. I can see it dripping in the primarys and it drips out the primary throttle shaft on the passenger side. Am I missing something? Anyone else have this problem? Possible solutions? Thanks
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2461668
03/05/18 09:10 PM
03/05/18 09:10 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What is the fuel pressure from the pump?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Thermo Quad Floods Over Help [Re: amxautox] #2461673
03/05/18 09:16 PM
03/05/18 09:16 PM
NE
NE
Not sure, I'll have to check that, think its a stock mechanical pump though
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2461683
03/05/18 09:31 PM
03/05/18 09:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Main body warped or cracked.
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2461693
03/05/18 09:54 PM
03/05/18 09:54 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
It sounds like the fuel is boiling in the bowls. If you have vertical space you might consider a thermoplastic carb spacer and a heat shield.
Re: Thermo Quad Floods Over Help [Re: John_Kunkel] #2461703
03/05/18 10:09 PM
03/05/18 10:09 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
If you run it and shut it off while it's cold, does it overflow? If not, you might be able to rule out fuel pressure and look more at heat related causes. However, I think the Thermoquads have a pretty large bowl vent, so it's hard to believe the bowls could be pressurizing (from fuel vaporizing) and forcing fuel out when you shut it off. Just a thought.
Re: Thermo Quad Floods Over Help [Re: BLACKHEMIRR] #2461706
03/05/18 10:17 PM
03/05/18 10:17 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
Oops. Dynorad beat me to it. Sorry
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2461711
03/05/18 10:21 PM
03/05/18 10:21 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
both styles of floats can sink after years of use, with brass you can usually feel gas sloshing inside. The wells will leak after years also and I've had good luck using JB weld to glue them back on
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2461774
03/06/18 12:19 AM
03/06/18 12:19 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep, my guess is a bad float or a bad float adjustment.
Re: Thermo Quad Floods Over Help [Re: ScottSmith_Harms] #2462289
03/06/18 10:41 PM
03/06/18 10:41 PM
NE
NE
Thank you for the thoughts thus far. This is where I am now.
does it with engine cold or hot
has about 4-5 psi fuel pressure
floats and float levels are good
tested needle and seats and they are good
plastic body not cracked or warped
epoxied jet bowls are good, no leaks
could the gaskets / o-rings for the 2 aluminum tubes from the upper aluminum top that seal next to the jets in the plastic body cause flooding over??
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2462318
03/06/18 11:20 PM
03/06/18 11:20 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
That was something that I forgot to mention and should be looked at, they get compressed and don't work like they should over time
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2462327
03/06/18 11:28 PM
03/06/18 11:28 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
The O-rings at the base of the bowl like mentioned above(I had one fall out or missed on install once,had a little fire!) Possibly try lowering the float level a tiny bit from spec it may help.
Re: Thermo Quad Floods Over Help [Re: moparpoolman] #2462383
03/07/18 01:25 AM
03/07/18 01:25 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, those O-rings should be square shouldered (look like a tiny slice of rubber hose). Round O-rings (found in some rebuild kits) can sometimes leak.
Re: Thermo Quad Floods Over Help [Re: ScottSmith_Harms] #2463339
03/08/18 09:28 PM
03/08/18 09:28 PM
NE
NE
Seems to be the o-ring seals, changed them and not flooding over any more. Thanks
