Cuda air box diverter rubber gasket #2460948
03/04/18 04:05 PM
03/04/18 04:05 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Does anyone make or carry the rubber gasket that fits around the diverter flap in the driver side air box on a non a/c 1970 Cuda? Mine is not the best. 🤔
Re: Cuda air box diverter rubber gasket [Re: gregok] #2460951
03/04/18 04:08 PM
03/04/18 04:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Cuda air box diverter rubber gasket [Re: DAYCLONA] #2461061
03/04/18 07:39 PM
03/04/18 07:39 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I will contact them, thanks.
Re: Cuda air box diverter rubber gasket [Re: gregok] #2461796
03/06/18 12:44 AM
03/06/18 12:44 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
That rubber was "over molded" on the metal door. Basically the metal door was put in the mold and the rubber molded around it. To replace it the rubber would have to be removed and them molded onto the door again. So basically, there's no aftermarket replacement for these. I usually pick up a bunch of old beat up fresh air vents when I'm at the swaps and sell the good (or not so bad) doors out of them.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Cuda air box diverter rubber gasket [Re: 71TA] #2461972
03/06/18 01:06 PM
03/06/18 01:06 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I talked to you yesterday about this, thanks for the info. Looking forward to the other stuff I ordered from you.
