Diamond piston/ring problem **UPDATE**
#2460715
03/04/18 02:15 AM
03/04/18 02:15 AM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Anyone one here ever run into this?? Diamond custom pistons, piston card calls for 1/16 x 1/16 x 3/32 rings, 4.600 bore. I got Mahle rings, correct size and fitted them to the bore. When I try to load the piston into the cylinder, the piston gets stuck in the ring compressor (tapered sleeve, correct size). After getting the piston assembly unstuck (without damaging anything!!), and doing a lot of investigating, I find that the top ring is bottoming out in the piston. Everything else is fine. I go retrieve the old rings that came off these pistons and find that width of the old ring is .169" (not top to bottom, but from the face of the ring to the inside diameter). The new top ring is .194", and the ring gap in the cyl bore is correct at .021", but when it is on the piston and "bottomed out", the gap is in excess of .030" and the diameter of the ring at that point is in excess of 4.602". I have the actual work order from when the pistons were made and it list the rings as 4.600b 1/16ap x 1/16nap x 3/16std. At this point I'm standing here going WTH?? Any suggestions other than calling Diamond on Monday?
Thanks, Brian
Re: Diamond piston/ring problem
[Re: '72CudaRacer]
#2460721
03/04/18 02:41 AM
03/04/18 02:41 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
The rings must be the wrong radial thickness. The proper rings have to give you the proper back clearance. Iff the old rings were .069” and it gives you correct back clearance or gap, the new rings radial thickness is incorrect. Did diamond supply the rings to you? Some ring manufacturers will back cut the rings to thinner dimensions. I had total seal back ut my rings for example. Maybe those can be corrected?
[Re: Chargerfan68]
#2460728
03/04/18 02:57 AM
03/04/18 02:57 AM
'72CudaRacer
Mooresburg, Tn
Iff the old rings were .069” and it gives you correct back clearance or gap, The old rings were gapped for nitrous use (but not used), top ring gap was over .030". This owner will not use nitrous, that was one of the reasons for me fixing the engine. Brian
[Re: dvw]
#2460795
03/04/18 11:49 AM
03/04/18 11:49 AM
'72CudaRacer
Mooresburg, Tn
Call Total Seal and order the correct top rings. You can buy just the 8 you need. Doug Well Doug, this has to be the best news that I've heard yet. Thanks, Brian
[Re: Cab_Burge]
#2460796
03/04/18 11:51 AM
03/04/18 11:51 AM
'72CudaRacer
Mooresburg, Tn
If this is a street or non serious race motor have the piston ring grooves cut to the proper depth for these rings and make sure and get the back spacing depth correct also This is a 622 ci, for sure not a street engine. But I thought it might be a option. Brian
[Re: dvw]
#2460816
03/04/18 12:20 PM
03/04/18 12:20 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Call Total Seal and order the correct top rings. You can buy just the 8 you need. Doug I agree. I wouldn't be machining pistons or rings. I would get the proper rings for the piston application. Modifying parts would only complicate matters down the road on the next freshen up.
[Re: '72CudaRacer]
#2460819
03/04/18 12:25 PM
03/04/18 12:25 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
Just need the correct radial sized top ring. They are made in various sizes to fit various manufacturers piston specs.
[Re: Cab_Burge]
#2460887
03/04/18 02:10 PM
03/04/18 02:10 PM
Posts: 1,505 TN
SCATPACK 1
TN
If this is a street or non serious race motor have the piston ring grooves cut to the proper depth for these rings and make sure and get the back spacing depth correct also this. It should give you more ring control and less ring roll over or flutter at high RPM
Old Geezer Racing
[Re: Chuck@Best_Machine]
#2460905
03/04/18 02:31 PM
03/04/18 02:31 PM
'72CudaRacer
Mooresburg, Tn
Are you sure the radial on the old ring is .069 ? A normal backcut 1/6th ring is .170 and a normal non back cut is around.200 If you really needed a 1/16th (.062) backcut to .069 it would almost be square. If this is the case you have a piston problem I believe that you are correct, Sir. My mistake (I corrected my original post). A good reason why mechanics shouldn't try to be machinist when its late and they are tired and annoyed. Thank you. Brian
#2460955
03/04/18 04:17 PM
03/04/18 04:17 PM
'72CudaRacer
Mooresburg, Tn
Your welcome. So all you need to fix this is a set of backcut rings Is a item that would be on the shelf or is it a custom thing? Doug suggested Total Seal, sounds like he has experience. Brian
