Re: If you knew then what you know now...
[Re: BradH]
#2460118
03/02/18 08:38 PM
03/02/18 08:38 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The only thing I would have changed is I would have bought my heads up car while I was younger and my son still lived at home. At my age it’s hard doing a class like that by yourself. It may end up being another bracket car
[Re: BradH]
#2460143
03/02/18 09:09 PM
03/02/18 09:09 PM
Posts: 4,457 Washington
madscientist
Washington
I would have never started.
[Re: BradH]
#2460170
03/02/18 09:28 PM
03/02/18 09:28 PM
Posts: 43,204 Bend,OR USA
Cab_Burge
... would you have made different decisions as far as how you approached racing, or your choice of builds, or... ??? I would have never built and raced a 1970 Baracuda 4 speed with a Hemi in NHRA stock on a 9 inch wide slick I should have weighed that car first as far as how much weight on the front tires and rear tires with me in it It had 2160 Lbs. on the front tires and 1280 lbs. on the rear without me in it back in 1976 before NHRA required the drivers weight in the drivers seat I never raced that car again after weighing it that day That car had a minimum weight of 3440 Lbs. with out the driver after a run back then
[Re: BradH]
#2460172
03/02/18 09:32 PM
03/02/18 09:32 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
Dana 60 instead of 8 3/4, Super Sprag, LBA valve body and aftermarket front drum in 727....DAMHIK................
Curator at Adams County Speed Shop
[Re: BradH]
#2460185
03/02/18 10:05 PM
03/02/18 10:05 PM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
I would have started racing at a younger age, and learned how to do more on my own sooner like welding, building transmissions and rear ends. Lastly I wish I found this forum sooner!
[Re: BradH]
#2460216
03/02/18 10:46 PM
03/02/18 10:46 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I would of taken photos of things I built, I wouldn't have taken 8 years off.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: BradH]
#2460232
03/02/18 11:26 PM
03/02/18 11:26 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
When I was 10 years old I was going to the track with my Dad racing his 63 Max Wedge car, about then he was 2 tenths off the Australian A/MP record before he threw the Brooks rods out the side of the block, that was 75/76, 20 years later we got the car back and I found 5.14 gears in the diff !!! What RPM is that ? 120mph 32" tire.
Im no guru but Im sure I could have got that record.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: BradH]
#2460235
03/02/18 11:39 PM
03/02/18 11:39 PM
Posts: 326 Alberta
Wookie316
Alberta
I would have done more research and chatted with more people before starting a build. Would of went to an aftermarket block out of the gate. Doing those simple things and I’d have enough $ left over to do a second car. That I know for sure.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: BradH]
#2460250
03/03/18 12:06 AM
03/03/18 12:06 AM
Posts: 570 UK
rb446
UK
Building my 440SP motor with stock pistons and that 290@.050 solid wasn't the ticket, running the 14x32's @4.5psi was no good just because everyone else ran them at that back then, and the 90/10's weren't the best, probably would've done better with some used stock shocks, too much front end rise, apart from that the car still ran well and managed 10.7's with 2.14 906's but I'm sure I could've gone quite a bit quicker today with the same set up just changing those things, at the end of the day my goal was a 9 sec pass which I managed with a small shot of spray so not a bad way to bow out of the sport in 1990.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2460252
03/03/18 12:20 AM
03/03/18 12:20 AM
Posts: 4,680 Wichita
GY3
Wichita
I would have spent more money on getting good suspensions and rearends under my cars.
Experimenting with 8 3/4 rears and Superstock springs was an exercise in wallet lightening and not much else.
