Page 3 of 5 1 2 3 4 5
Re: Guess my Dyno numbers [Re: Thumperdart] #2458928
02/28/18 03:51 PM
02/28/18 03:51 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Thumperdart
Why so lean...........
That's the first thing I noticed, too. scope
Chuck: Is that an out-of-the-box Q-Series 950, by chance?
Re: Guess my Dyno numbers [Re: 10sec440] #2458966
02/28/18 05:13 PM
02/28/18 05:13 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline
Your right, the data says its lean. As nice as it is to be overloaded with data, sometimes you have to do what the engine wants. Plugs looked perfect as well as the exhaust ports. It was a Q950 Stock jetting was way to rich, I would have liked to try a 1050 but didn't have any on hand. This is for a 100% street car 68 Road Runner 4 Speed, it should be a lot of fun
Re: Guess my Dyno numbers [Re: Chuck@Best_Machine] #2458978
02/28/18 05:35 PM
02/28/18 05:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Anytime a hot/bigger motor runs a 4150 type carb they CAN go very rich due to the added velocity that larger cubes create and are more sensitive to tune from my experience. The RIGHT Dommy will smooth that right out.......... beer
Re: Guess my Dyno numbers [Re: 10sec440] #2459002
02/28/18 06:22 PM
02/28/18 06:22 PM
AndyF Offline
AndyF  Offline
The O2 sensor information on a dyno can often be wrong. A small air leak into the exhaust system will make everything look lean even if the engine is running just fine.
I also learned the hard way that O2 sensor data can be messed up electronically. It is a small digital signal and there are lots of ways to mess up small digital signals.
Re: Guess my Dyno numbers [Re: Thumperdart] #2459029
02/28/18 07:30 PM
02/28/18 07:30 PM
The AFR read out says lean, the BSFC says a little fat up high.
Test,test and test some more until it goes slower or looses power, correct work
Maybe it needs a slightly bigger high speed bleeds work
I agree on a bigger CFM carb. to help eliminate the manifold vacuum increasing restricting the air flow into the motor work
Re: Guess my Dyno numbers [Re: Cab_Burge] #2459052
02/28/18 08:27 PM
02/28/18 08:27 PM
BradH Offline
BradH  Offline
This has been debated / argued before, but you cannot tune a carb by BSFC #s. BSFC doesn't tell anything about the air-fuel ratio. It's simply a measure of efficiency of the amount of fuel used to make the power recorded.
EDIT: LINK to article on BSFC vs Air-Fuel Ratio...
Re: Guess my Dyno numbers [Re: Chuck@Best_Machine] #2459067
02/28/18 09:06 PM
02/28/18 09:06 PM
BradH Offline
BradH  Offline
Originally Posted By Chuck@Best_Machine
... It was a Q950 Stock jetting was way to rich...
How much did you have to lean it out from the standard tune? I'm a little surprised you said it was too rich from what I recall the out-of-the-box settings are.
Re: Guess my Dyno numbers [Re: Cab_Burge] #2459085
02/28/18 09:56 PM
02/28/18 09:56 PM
I agree!
Of course the customer will add a air cleaner and full exhaust and that will change things to so no reason to chase a couple HP onthe dyno and like most guys he will do a little tuning once it's in the car. Reliability and driveability are more important.
Just for example, a A/SA Max Wedge on our dyno will make 595 hp and run 10.20 at 3400lbs. So how fast would you think a 3600 lb 4 speed Road Runner would go ?
Re: Guess my Dyno numbers [Re: BradH] #2459091
02/28/18 10:06 PM
02/28/18 10:06 PM
I believe it was 4 front and rear
Re: Guess my Dyno numbers [Re: Chuck@Best_Machine] #2459104
02/28/18 10:32 PM
02/28/18 10:32 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
This should be a new thread all by itself!
popcorn
Re: Guess my Dyno numbers [Re: PorkyPig] #2459108
02/28/18 10:42 PM
02/28/18 10:42 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
popcorn
iagree I know some 4 speed b bodys that have "650" car show horsepower and probably go bottom 13s or maybe 12s in good air laugh2 boogie
Re: Guess my Dyno numbers [Re: Chuck@Best_Machine] #2459156
02/28/18 11:48 PM
02/28/18 11:48 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
I am not surprised now by this . I had to pull 4 or 5 jets out of the front and maybe 2 rear when I went from 440ci to 505ci. Motor just works the carb harder especially if carburation is a little undersized .
Tex
PS : my 505 with a hair more comp and bit more cam makes 600-620 FWHP . With a 4150 carb , mufflers and exhaust to diff . I am not sure this one will go too much more .
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Guess my Dyno numbers [Re: Thumperdart] #2459298
03/01/18 10:46 AM
03/01/18 10:46 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Because lean is Mean................!
Re: Guess my Dyno numbers [Re: tex013] #2459441
03/01/18 03:55 PM
03/01/18 03:55 PM
BradH Offline
BradH  Offline
Makes sense, in that I'd suspect that whomever is in charge of the calibration for those carbs probably isn't told the intended application is 500 cubes making 600++ HP. Yeah, the bigger engine would create more signal than the carb was originally tuned for, whereas a too-big carb would need to be richer to crutch the lack of signal.
Re: Guess my Dyno numbers [Re: PorkyPig] #2459443
03/01/18 04:00 PM
03/01/18 04:00 PM
BradH Offline
BradH  Offline
popcorn
You're right. That way I can ask Chuck more questions and not derail this thread, as well as add my own "before" data and "after" predictions based on my latest engine dyno results. wink
Re: Guess my Dyno numbers [Re: DoubleD] #2459444
03/01/18 04:03 PM
03/01/18 04:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya, mean on rings, pistons and bearings............ whistling
Re: Guess my Dyno numbers [Re: Thumperdart] #2459447
03/01/18 04:08 PM
03/01/18 04:08 PM
BradH Offline
BradH  Offline
I was going to say something along the same lines, but ya' treed me.
Re: Guess my Dyno numbers [Re: BradH] #2459518
03/01/18 06:36 PM
03/01/18 06:36 PM
Sydney,Australia
Sydney,Australia
.[/quote]
Makes sense, in that I'd suspect that whomever is in charge of the calibration for those carbs probably isn't told the intended application is 500 cubes making 600++ HP. Yeah, the bigger engine would create more signal than the carb was originally tuned for, whereas a too-big carb would need to be richer to crutch the lack of signal. [/quote]
Spot on Brad , the too rich I encountered with the Modman and 440ci . Seen it a few times on the dyno , raw fuel/black smoke but AFR showing lean .
Tex
New best MPH 130.32
Re: Guess my Dyno numbers [Re: tex013] #2459578
03/01/18 08:41 PM
03/01/18 08:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Tex [/quote]
NO outta the box carb will be ideal for YOUR application at least not any that I've heard or seen..... beer
Re: Guess my Dyno numbers [Re: Thumperdart] #2459798
03/02/18 06:37 AM
03/02/18 06:37 AM
Sydney,Australia
Sydney,Australia
Tex [/quote]
NO outta the box carb will be ideal for YOUR application at least not any that I've heard or seen..... beer [/quote]
You got that Dom
June is off season , so then i will set up intakes to try dominator and modman again
Tex
New best MPH 130.32
