left 340 exhaust manifold gasket #245903
03/07/09 02:37 PM
03/07/09 02:37 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
Is there any aftermarket companys making the correct gasket for the left manifold for my 71 340 Dart??
1971 340 Swinger Canadian Car
1972 Dodge Dart Prostreet 440
2013 Dodge Ram 1500
Re: left 340 exhaust manifold gasket [Re: dalei989] #245904
03/07/09 03:05 PM
03/07/09 03:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you can get it DIRECTLY from an MP supplier
Re: left 340 exhaust manifold gasket [Re: JohnRR] #245905
03/07/09 06:23 PM
03/07/09 06:23 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
I did find these from several suppliers but the cost is "WOW", cheapest so far is 170.00. thanks
2013 Dodge Ram 1500
Re: left 340 exhaust manifold gasket [Re: dalei989] #245906
03/07/09 06:43 PM
03/07/09 06:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Check with a US supplier , I would have told you to contact Troy at west oaks dodge , but they are out of business , maybe member johncambridge ?
Mopar had them repopped so anyone that is selling them got them from mopar .
Re: left 340 exhaust manifold gasket [Re: dalei989] #245907
03/07/09 07:54 PM
03/07/09 07:54 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
you better buy it, retail is now right at $195 . dealer cost is just over $160
Re: left 340 exhaust manifold gasket [Re: dalei989] #245908
03/08/09 01:46 AM
03/08/09 01:46 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
What am I missing here? A GASKET costs 160$?
I can't afford this. mark
Re: left 340 exhaust manifold gasket [Re: a12superbee] #245909
03/08/09 01:58 AM
03/08/09 01:58 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It also functions as a heat shield.
Re: left 340 exhaust manifold gasket [Re: autoxcuda] #245910
03/08/09 02:06 AM
03/08/09 02:06 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Before it was reproduced NOS originals were selling on Ebay for $300+ & I saw one go for $470.00
But I think that gasket was used from 68-70... 71 is a different manifold & may not even use a gasket...
Re: left 340 exhaust manifold gasket [Re: a12superbee] #245911
03/08/09 02:14 AM
03/08/09 02:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you have an A12 , if it were a gasket specific to that it would be 300
Re: left 340 exhaust manifold gasket [Re: 1_WILD_RT] #245912
03/08/09 02:17 AM
03/08/09 02:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
71 a body used the same manifold as 68-70
A bodies always had a heatsheild as a part of the left manifold gasket up to at least 72 , even my dads 72 318 duster had the upswept manifold and had a heat shield/gasket .
Re: left 340 exhaust manifold gasket [Re: JohnRR] #245913
03/08/09 02:29 AM
03/08/09 02:29 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A bodies always had a heatsheild as a part of the left manifold gasket up to at least 72 , even my dads 72 318 duster had the upswept manifold and had a weat shield/gasket .
Your right..I think in E body...
Re: left 340 exhaust manifold gasket [Re: 1_WILD_RT] #245914
03/08/09 03:54 AM
03/08/09 03:54 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
I thought a bodys were affordable.
Re: left 340 exhaust manifold gasket [Re: a12superbee] #245915
03/08/09 11:16 AM
03/08/09 11:16 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Shield shown is correct for 1969 to 1971,
I'm not 100% but I think 1972 is when they went to a 2 piece shield on A-bodies ( E-bodies stopped using it after 1970 )
The 1968 shields - the actual shields are 2 seperate pieces and don't connect in the center above the manifold like to 69 up one does
Re: left 340 exhaust manifold gasket [Re: gtx6970] #245916
03/10/09 02:05 AM
03/10/09 02:05 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The new reproductions are nice but just in case the smaller details are important to you they do vary from originals. Here's how;
The reproductions have the correct Mopar part number but it is stamped in the wrong direction and is a different font as compared to originals.
They lack the McCord stamped number entirely (as all originals had)
The Pentastar looks a bit different.
