Can anyone confidently identify this noise? A833 4 speed
#2458732
02/28/18 08:35 AM
02/28/18 08:35 AM
moparedtn
moparedtn
1968 Plymouth GTX, mild early 70's 440, 11" CenterForce DualFriction, new input bushing, 23 spline of unknown sourcing (looks to never have been apart, shifts great though). 3.55 SG fresh, original driveshaft. There is a noise that sounds much like an old school buzzer that eminates at speeds above 50mph and remains constant above that; it goes away consistently below that speed and finally does go away at 70+ mph. Everything in the clutch/flywheel is new and Brewer's sourced. Tailshaft bushing and seal are also new. Speedo gear is new as well; I had it out to inspect and it's flawless and I've eliminated the cable as a possibility as well. The noise is not engine speed dependent; only vehicle speed makes it happen, whether clutch in/out, regardless of gear (or in neutral). Revving the engine in neutral, no difference. It comes on all at once, like a light switch being flicked. I have a video on YouTube of it occurring in real time: A833 Noise - Speedometer Disconnected at Transmission Can anyone confidently recognize this noise? TIA!!
Re: Can anyone confidently identify this noise? A833 4 speed
[Re: ]
#2458833
02/28/18 01:38 PM
02/28/18 01:38 PM
moparedtn
moparedtn
Somebody surely recognizes that sound??
[Re: ]
#2458853
02/28/18 02:02 PM
02/28/18 02:02 PM
Posts: 4,454 Morristown Tn.
71birdJ68
Morristown Tn.
Sounds kind of like some sort of bushing, or bearing. Does the engine have a cast crank, and if so, does it have the proper flywheel, and balancer? I'm in Morristown, maybe we can get together and figure it out.
[Re: 71birdJ68]
#2458993
02/28/18 06:03 PM
02/28/18 06:03 PM
moparedtn
moparedtn
Sounds kind of like some sort of bushing, or bearing. Does the engine have a cast crank, and if so, does it have the proper flywheel, and balancer? I'm in Morristown, maybe we can get together and figure it out. Hey, that's very gracious of you. I'd kill for access to a lift right now. :-) Darn good question on the engine and I don't know for sure, but when I got the engine in shipping, I took pictures and posted on the FBBO forum and asked others' opinions. The consensus was that it was forged and since it came with those types of balancers and flywheels, I called it good. If the problem was a gradual harmonic vibration that became stronger (or lesser) with speed, I'd certainly be looking at that possibility, though, sure - but it isn't, as you can hear. This comes on all at once with a certain speed.
[Re: buildanother]
#2458995
02/28/18 06:05 PM
02/28/18 06:05 PM
moparedtn
moparedtn
I hear it, sure don't know what it is. But first thing I would do is grab shifter handle, try moving a hair each way to try to change noise. gives ya a better idea where to look. Be very weird if it ends up as a relay buzzing somewhere. Oh trust me, the shifter got wrangled every which way, including "more in gear", out of gear, every position short of reverse while going down the highway. Nada. Sounds like an old seat belt buzzer, eh? :-) It isn't. There's nothing in that area electrical, short of the reverse light switch of course.
[Re: Brewzer67]
#2458996
02/28/18 06:07 PM
02/28/18 06:07 PM
moparedtn
moparedtn
That sounds like a speedometer cable binding at/near the transmission to me. That is exactly what my dremel tool extension cable sounds like when I get it in too tight of a loop/radius. I would disconnect the speedo cable and see if it goes away. If the cable is clipped to the floorboard to keep it in place it would make a perfect sounding board for it. Thanks (and I agreed with you initially because that's what it sounds like), but as I posted, the speedo gear and cable are no longer suspects. In fact, the speedo cable is disconnected at the transmission at the time I made the video in the hopes that would have cured it. Sadly, it didn't.
[Re: ]
#2458997
02/28/18 06:09 PM
02/28/18 06:09 PM
moparedtn
moparedtn
Thanks for all the guesses so far. I appreciate the help! Man, I'm hoping someone hears it and says "well sure, dumbass, it's this!" :-)
[Re: moparpoolman]
#2459088
02/28/18 10:01 PM
02/28/18 10:01 PM
moparedtn
moparedtn
Does it do it when in 2nd? Could be the shift fork rattling? I tried every shifter position short of reverse. Thanks!
[Re: ]
#2459146
02/28/18 11:37 PM
02/28/18 11:37 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
It does sound like a dry bushing but you have covered all the usual suspects. The only thing I can think of would be trying a differn't speedo adapter then see if someone can loan you a differn't drive shaft. You cant feel it through the shifter? Does it stop when you kick it into neutral? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2459191
03/01/18 12:44 AM
03/01/18 12:44 AM
moparedtn
moparedtn
It does sound like a dry bushing but you have covered all the usual suspects. The only thing I can think of would be trying a differn't speedo adapter then see if someone can loan you a differn't drive shaft. You cant feel it through the shifter? Does it stop when you kick it into neutral? Gus I gotta figure if the speedo pinion is in perfect shape (it is) and the speedometer itself works flawlessly, then I got the "lash" set correctly on the adapter. I suppose I could just pull out the pinion and plug off the hole in the adapter, then give that a shot? I'm gonna do it. What would it hurt to try? Thanks! No sir on the neutral. Again, shifter position and clutch position do not affect the noise at all. Any gear or neutral, doesn't matter. Thanks!
[Re: ]
#2459353
03/01/18 12:53 PM
03/01/18 12:53 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Can anyone confidently recognize this noise? TIA!! [/quote]
Sounds to me like rear main bearing in the transmission??????
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2459446
03/01/18 04:07 PM
03/01/18 04:07 PM
Posts: 10,723 North Dakota
6PakBee
North Dakota
Okay, if I've got this right.
1) Noise is dependent on road speed, not engine speed. 2) Noise is present in neutral with enough road speed. 3) Noise is present with clutch depressed and enough road speed.
If the noise is present in neutral with the clutch depressed and enough road speed, the only thing that is rotating is the output shaft. I think the rear main bearing is a good guess.
[Re: 6PakBee]
#2459463
03/01/18 04:39 PM
03/01/18 04:39 PM
68LAR
South Park, Pa.
If the noise is present in neutral with the clutch depressed and enough road speed, the only thing that is rotating is the output shaft. I think the rear main bearing is a good guess. 1) as long as the rear tires are rotating, the rear main bearing is rotating. 2) As long as the rear tires are rotating, the rear main bearing is rotating 3) as long as the rear tires are rotating, the rear main bearing is rotating. When clutch is depressed, the input shaft stops rotating, hense, the front bearing stops rotating.
[Re: ]
#2459523
03/01/18 06:38 PM
03/01/18 06:38 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
It could also be the rear bushing in the tailshaft, where the slip yoke rides... Pull out the slip yoke and see what the machined surface looks like.
[Re: 71birdJ68]
#2459525
03/01/18 06:39 PM
03/01/18 06:39 PM
Cuda340
Wheatfield, NY
What are you mean when you say the lash is correct on the pinion adaptor? There are three different settings for the speedo adapter depending what tooth the speedo gear is. I think that is what he was referring to .
