Re: big block rods
[Re: Wedgeman]
#2456972
02/24/18 10:26 PM
02/24/18 10:26 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I went 9.80’s @ 2800 pounds over 25 years ago but I throw them on a he scrap pile now and buy better rods. I did change out the rod bolts for Dirrect Connection ones and did some grinding on the beams.
Re: big block rods
[Re: Wedgeman]
#2456978
02/24/18 10:31 PM
02/24/18 10:31 PM
Posts: 4,210 New York
polyspheric
New York
Rating connecting rods by HP and torque is completely a marketing trick. What breaks rods is reciprocating weight times RPM as the piston passes through TDC on the intake stroke, and it would happen with the ignition off.
Boffin Emeritus
Re: big block rods
[Re: polyspheric]
#2456986
02/24/18 10:45 PM
02/24/18 10:45 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ll add that my engine had a stock crank and very heavy TRW pistons. We didn’t have many choices back then.
Re: big block rods
[Re: polyspheric]
#2456992
02/24/18 10:52 PM
02/24/18 10:52 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Rating connecting rods by HP and torque is completely a marketing trick. What breaks rods is reciprocating weight times RPM as the piston passes through TDC on the intake stroke, and it would happen with the ignition off. The stock rods are pretty good around 5800, past 6200 rpm things get worse. If you plan on higher rpms then that on a regular basis, after market rods for sure. Sure they can be zinged up to 7200, 8000 rpm and survive, like in the water box by accident. But you surely don't want to race them at those rpms
Re: big block rods
[Re: Sport440]
#2456998
02/24/18 11:00 PM
02/24/18 11:00 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
4.56 gears, 14-31 slick. Never broke a rod but after 3 years of racing twice a weekend every crank I had magnafluxed during rebuild had cracks
Re: big block rods
[Re: Wedgeman]
#2457014
02/24/18 11:20 PM
02/24/18 11:20 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have an old 440 that was my first race motor in my 63 Plymouth, it is a cast crank LY rod engine with TRW's, belted the living daylights out of it running a best of 9.69 @ 135 with a small shot of gas. It has had a sleeve fitted to one cylinder after a pin walked but this engine still lives and is a 10.90 deal in my sons street valiant. Cast Crank LY rod action https://www.youtube.com/watch?v=nt4DpdAI7Fk
1963 Plymouth Max Wedge 1971 Barracuda
Re: big block rods
[Re: Wedgeman]
#2457307
02/25/18 02:27 PM
02/25/18 02:27 PM
Posts: 570 UK
rb446
UK
'69 Cuda, 3000lbs 14x32, 4.88's, Stock blueprinted 440 6-pack motor, polished beams/shot peened good bolts on rods, turned 6600 NA, 7000 w/125hp N20, 7300 w/150hp N20 to run 9.96. No issues, had external oiling, but wouldn't hit that 7300 run more than once, didn't like the song the motor sang at those rpms.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
Re: big block rods
[Re: Wedgeman]
#2457430
02/25/18 06:53 PM
02/25/18 06:53 PM
polyspheric
New York
Steel rods can be tortured many times, and come back to fight another day. An aluminum rod, once stretched, is a ticking bomb.
Boffin Emeritus
Re: big block rods
[Re: Wedgeman]
#2458621
02/27/18 11:22 PM
02/27/18 11:22 PM
ozymaxwedge
Australia
Woww! They are that strong ? So they should live long in a 650hp motor ?
440 source sells a set for 250$......hummmm what to do ?
Dan But are the Source rods as good as the old LY's ?? Not sure.
Re: big block rods
[Re: ozymaxwedge]
#2458633
02/27/18 11:49 PM
02/27/18 11:49 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If it was me I would spend a few extra bucks and see if Scat offers a big block rod. I had a set of Scat small block rods I bought in a package deal and they looked real nice. Very reasonable too. At least they come with 7/16 rod bolts. it cost a fair amount of money just to prep the old stock rods.
Re: big block rods
[Re: Wedgeman]
#2458646
02/28/18 12:21 AM
02/28/18 12:21 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Dan In case you missed Polyspheric's earlier post above. Rating connecting rods by HP and torque is completely a marketing trick. What breaks rods is reciprocating weight times RPM as the piston passes through TDC on the intake stroke, and it would happen with the ignition off. Kevin
Re: big block rods
[Re: Twostick]
#2458655
02/28/18 12:34 AM
02/28/18 12:34 AM
Sport440
Canton, Ohio
Dan In case you missed Polyspheric's earlier post above. Rating connecting rods by HP and torque is completely a marketing trick. What breaks rods is reciprocating weight times RPM as the piston passes through TDC on the intake stroke, and it would happen with the ignition off. Kevin Also, what Poly left out, was duty cycles, miles/rpm over the rods lifetime. That's most likely a unknown. Are they at the end of their life cycle or somewhere in between.
