Throttle cable setup? #245851
03/07/09 01:20 PM
03/07/09 01:20 PM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
What kind of throttle cable setups are you guys using with tall (2") carb spacers or throttle stops? I still have the stock gas pedal in the car. I would have to make a cabl bracket for the carb or intake manifold as the one I have now will not go high enough.
Re: Throttle cable setup? [Re: JandJ_Racing] #245852
03/07/09 01:20 PM
03/07/09 01:20 PM
Way North Illinois
Way North Illinois
One more
Re: Throttle cable setup? [Re: JandJ_Racing] #245853
03/07/09 01:23 PM
03/07/09 01:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I use the Jegs alum piece designed for the stock mopar cables.
Re: Throttle cable setup? [Re: JandJ_Racing] #245854
03/07/09 10:25 PM
03/07/09 10:25 PM
NC
440Jim Offline
440Jim  Offline
NC
I finally went with the Lokar cable after my '69 factory cable broke (most of the strands, caught it before it broke all the way). I really like their cable. But it did take some work and I use a carb mounted cable holder, that is nice too.
Re: Throttle cable setup? [Re: 440Jim] #245855
03/07/09 10:28 PM
03/07/09 10:28 PM
NC
440Jim Offline
440Jim  Offline
NC
This is the mod to the stock pedal in my '69 Dart. Not a big deal.
Re: Throttle cable setup? [Re: 440Jim] #245856
03/07/09 10:29 PM
03/07/09 10:29 PM
NC
440Jim Offline
440Jim  Offline
NC
The finish pedal install.
Post deleted by Defbob [Re: 440Jim] #245857
03/07/09 10:35 PM
03/07/09 10:35 PM
Re: Throttle cable setup? #245858
03/07/09 11:07 PM
03/07/09 11:07 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Just for the record, No mods were done to either of my pedals.
Re: Throttle cable setup? [Re: WILD BILL] #245859
03/07/09 11:40 PM
03/07/09 11:40 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
john make sure that the pedal has a dead stop so the cable isn't pulled all the way be pedal. I've tried mine twice before we figured that i was pulling the cable out of that set screw .I then drilled it out and put a bigger screw in it.I think i was making it worse by 2 stepping alot of pressure on it.
good luck don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Throttle cable setup? [Re: 10 o to go] #245860
03/07/09 11:49 PM
03/07/09 11:49 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Re: Throttle cable setup? [Re: markz528] #245861
03/08/09 01:09 AM
03/08/09 01:09 AM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
I like the Lokar cable also, but you can take a small piece of flat medal and drill a hole in each end of it and make a extension for your stock cable also.
Re: Throttle cable setup? [Re: WILD BILL] #245862
03/08/09 09:40 AM
03/08/09 09:40 AM
NC
440Jim Offline
440Jim  Offline
NC
There may be some variance in pedals from Ma Mopar. The Lokar end has a barrel shape with a ball. The barrel dia wouldn't fit through my pedal so I enlarged it a tiny bit (7/64" bit). The ball part is larger and stops the cable from going through the pedal.
Re: Throttle cable setup? [Re: 440Jim] #245863
03/08/09 12:44 PM
03/08/09 12:44 PM
Way North Illinois
Way North Illinois
Yes my peal is mounted to a bracket that holds the whole mess to the firewall. Makes it a little easier to get to the cable with the motor in the car. The hole was 1/2" and the instructions call for 5/16" So I added the washer.
