Re: Big-block timing backing up
[Re: 70Drop]
#2457671
02/26/18 01:08 AM
02/26/18 01:08 AM
Posts: 43,198 Bend,OR USA
Cab_Burge
Which ignition control box are you using? Does it have a automatic retard option? If so, look there first
[Re: 70Drop]
#2457720
02/26/18 02:51 AM
02/26/18 02:51 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Yeah replace that gear first, hope it fixes the problem.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 70Drop]
#2457732
02/26/18 03:21 AM
02/26/18 03:21 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
If that doesn’t fix it, I’d put the timing light on another car just to make sure it’s not in the light.
[Re: 70Drop]
#2457850
02/26/18 01:32 PM
02/26/18 01:32 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Step one...... Retest with a timing light that has no dial back type circuits in it.
Ran into this years ago with a motor on the dyno using a dial back light that had never exhibited the issue before. Tried a non-dial back light...... Problem gone.
[Re: 70Drop]
#2457900
02/26/18 03:28 PM
02/26/18 03:28 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Would like to know how we know if the MSD does what it's programmed to do.With programmable timing and a map sensor to take out timing with boost,how can we tell??
[Re: 70Drop]
#2457934
02/26/18 04:34 PM
02/26/18 04:34 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I agree with the dial back timing light being suspect. The multi spark goes away real close to where you are seeing a timing change. That multiple spark transition to single spark will confuse the calculation of the strobe.
[Re: 70Drop]
#2457972
02/26/18 05:52 PM
02/26/18 05:52 PM
Posts: 481 Cheswick, PA
Bob_Spelic
Cheswick, PA
Same problem on my 572. On the dyno we saw about 4 degree retard between 6500 and 7500. MSD billet distributor. Since my application was drag only and I ran a 6200 stall converter, we set timing at 6500 on the dyno.
