Re: Will factory 440 block survive for very long at 800 HP level
[Re: BigHemiVegas]
#2456429
02/24/18 12:30 AM
02/24/18 12:30 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have split one through the mains and up into the bores mixing the water and oil, that was with a 440-528 and my 200 hp shot poor tune. That was about 8 years ago, I have not run the bottle since, we live and learn.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2456527
02/24/18 04:34 AM
02/24/18 04:34 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I have split one through the mains and up into the bores mixing the water and oil, that was with a 440-528 and my 200 hp shot poor tune. That was about 8 years ago, I have not run the bottle since, we live and learn. Quitter! I don't care how many parts I sacrifice to the god of speed, they will pry that nitrous button from my cold dead fingers!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2456529
02/24/18 05:08 AM
02/24/18 05:08 AM
ozymaxwedge
Australia
Hahahahaha You go hard Billy, I'll go aftermarket block and procharger one day, after I rob the bank.
[Re: BigHemiVegas]
#2456607
02/24/18 12:26 PM
02/24/18 12:26 PM
Posts: 4,210 New York
polyspheric
New York
Keep those positive comments coming. NOT!!!!
Boffin Emeritus
[Re: BigHemiVegas]
#2456648
02/24/18 01:56 PM
02/24/18 01:56 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Not mine and I don't remember where I found it but here it is for your viewing pleasure.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: Digger73]
#2456726
02/24/18 04:11 PM
02/24/18 04:11 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
When it comes to decision making on race parts or hot street car parts I always think of the worst case scenario, do I really want to run over the engine parts above 100 MPH ![work work](/ubbthreads/images/graemlins/custom/work.gif) Not me now ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) Been there done that way to many times ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) Be safe, buy good parts and pray they don't fail at speed that can hurt you and the car ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: BigHemiVegas]
#2456731
02/24/18 04:23 PM
02/24/18 04:23 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I prefer to use the best parts I can that are up to the task, or even overkill for what we are doing. Properly put together, maintained, kept fresh, and hopefully, live a long productive life. I'm definitely not in the "build, run it till it blows, rinse, repeat" crowd. I'm weird like that.
[Re: CMcAllister]
#2456744
02/24/18 04:38 PM
02/24/18 04:38 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Properly put together, maintained, kept fresh, and hopefully, live a long productive life. You are not alone...
[Re: CMcAllister]
#2456895
02/24/18 07:41 PM
02/24/18 07:41 PM
Posts: 4,075 Mo.
racerx
Mo.
I prefer to use the best parts I can that are up to the task, or even overkill for what we are doing. Properly put together, maintained, kept fresh, and hopefully, live a long productive life. I'm definitely not in the "build, run it till it blows, rinse, repeat" crowd. I'm weird like that. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) this is how I think also.
[Re: racerx]
#2456980
02/24/18 10:35 PM
02/24/18 10:35 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
650-700 HP. looks like the limit. others did better, others Not so much! take the advice. if not good luck. Remember you can only become a millionaire in Drag racing if you start out as a Billionaire!
Hell Hath No Fury Like Mine
[Re: dvw]
#2457432
02/25/18 06:55 PM
02/25/18 06:55 PM
Posts: 289 PA
Harry's Taxi 2
PA
Mine broke at about 200 passes, 6500 max, aluminum caps. Dynoed at 657hp. Took the crank, 4 rods/pistons, 8 push rods and valves. Doug What cubic inch? cyl.heads?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
