Neutral safety switch connection in racecar? #2456212
02/23/18 04:09 PM
02/23/18 04:09 PM
Penna
70satelliteguy Offline OP
Penna
Anyone have a reliable way to connect to the center prong so it does not come loose easily? I do not have or use the 3 prong plug that connects to the backup lights and neutral safety switch in a stock application. Have been using little cheap connector but it keeps coming loose. Nothing like having to crawl underneath the car in the staging lanes!!! Would a older 727 unit single connection work better and if so where would I get one?
Thanks Mike
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2456226
02/23/18 04:27 PM
02/23/18 04:27 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
The three prong wiring pigtail is available at auto parts store. I got one at Oreillys a couple years back. Part# pt5667. Borg Warner
I have soldered a wire to the center pin before. That worked out good.
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2456230
02/23/18 04:33 PM
02/23/18 04:33 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
ACDelco PT2139 amazon 21.90
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2456245
02/23/18 05:21 PM
02/23/18 05:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
What kind of shifter? Often times it's easier to use a shifter mounted switch. If the car is using the stock harness and starter relay, then a new 3 wire plug will fix you up. NAPA ECH EC187 Advance PT5667
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2457221
02/25/18 11:47 AM
02/25/18 11:47 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I went with this newer style N safe switch on my old car and got the pigtail at work for it. That old style connector was a joke.
Re: Neutral safety switch connection in racecar? [Re: J_BODY] #2457240
02/25/18 12:29 PM
02/25/18 12:29 PM
moparx Online content
moparx  Online Content
what is the application for that switch ?
beer
Re: Neutral safety switch connection in racecar? [Re: J_BODY] #2457280
02/25/18 01:33 PM
02/25/18 01:33 PM
Penna
Penna
"I went with this newer style N safe switch on my old car and got the pigtail at work for it. That old style connector was a joke. "
J body. Will this fit 727? Have a part Number? Pig tail that fits this?
Thanks Mike
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2457292
02/25/18 01:53 PM
02/25/18 01:53 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I think i have a extra one let me ck if so you can have it i can mail it to you
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2457357
02/25/18 04:13 PM
02/25/18 04:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Looks like an Autozone pt.# is CR446 for the switch and 1070 for the connector kit. Mid 2000s RWD truck
Re: Neutral safety switch connection in racecar? [Re: CMcAllister] #2457377
02/25/18 05:04 PM
02/25/18 05:04 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use a blue butt connector on the center pin and crimp it down to where it snaps off and on. Seems to work so far.
'63 Dodge 330
11.19 @ 121 mph
Re: Neutral safety switch connection in racecar? [Re: GY3] #2457400
02/25/18 05:52 PM
02/25/18 05:52 PM
Penna
Penna
"I use a blue butt connector on the center pin and crimp it down to where it snaps off and on. Seems to work so far."
That is what I have been doing but not having a lot of luck with that last year. The pins on my current switch are not in good shape so I am looking for something to permanently fix problem.
That new switch and plug looks like what I am looking for. Hope it works in 1967 727.
Mike
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2457443
02/25/18 07:16 PM
02/25/18 07:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the '67 727 has the original style valve body and rooster comb (middle in the pic below), it's not really compatible with the 3-prong switch.
Pre-'69 uses the single threaded stud switch.
Re: Neutral safety switch connection in racecar? [Re: John_Kunkel] #2457581
02/25/18 10:57 PM
02/25/18 10:57 PM
Penna
Penna
"If the '67 727 has the original style valve body and rooster comb (middle in the pic below), it's not really compatible with the 3-prong switch."
"Pre-'69 uses the single threaded stud switch."
Don't know what style rooster comb but now it has a transbrake valvebody. It has a 3 prong switch and the center prong works for the neutral safety . I tried using a 3 prong plug and wiring to all 3 wires separately but none of them seemed to work.
If that single stud style with a nut worked on my tranny I would be very happy.
Mike
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2457674
02/26/18 01:12 AM
02/26/18 01:12 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
CMcallister nailed it.... same switch that was on my diesel, and I'm betting your t-brake looks like the linkage to the right in Johns picture.
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2457969
02/26/18 05:48 PM
02/26/18 05:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Remove the switch and look in the hole; compare what you see to my pic.
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2458120
02/26/18 10:31 PM
02/26/18 10:31 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
On a race car I would use the neutral safety switch that is probably built into your aftermarket shifter to ground out the wire that now runs to factory switch. Then put a o-ring plug in the factory switch location.
"Just a Bracket car dressed up like a streetcar"
Re: Neutral safety switch connection in racecar? [Re: Just-a-dart] #2458303
02/27/18 12:16 PM
02/27/18 12:16 PM
Penna
Penna
Removed the switch and it is a blue A&A transbrake valvebody showing. .Can't tell what the rooster tail looks like. I think I am just going to Gorilla glue a connection to the center prong and be done with it.
Mike
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2458396
02/27/18 02:28 PM
02/27/18 02:28 PM
Make sure that Gorilla glue is NOT a insulator work scope
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2458473
02/27/18 05:09 PM
02/27/18 05:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What you're seeing is the plastic shoe on the rooster comb, they come in several colors. The single threaded stud switch (center in my pic) will work with the plastic shoe.
Re: Neutral safety switch connection in racecar? [Re: John_Kunkel] #2458563
02/27/18 08:33 PM
02/27/18 08:33 PM
Penna
Penna
Thank You John!!!
Mike
Re: Neutral safety switch connection in racecar? [Re: 70satelliteguy] #2458564
02/27/18 08:40 PM
02/27/18 08:40 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
John, where are you getting the single threaded switches? I had one go bad a while back and haven't been able to find any.
Re: Neutral safety switch connection in racecar? [Re: DblOJoe] #2458572
02/27/18 09:20 PM
02/27/18 09:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
They are getting kinda rare and the prices reflect that.
https://www.ebay.com/itm/1966-1967-1968-...ar/352290818819
