Re: Will factory 440 block survive for very long at 800 HP level
[Re: BigHemiVegas]
#2456429
02/24/18 12:30 AM
02/24/18 12:30 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have split one through the mains and up into the bores mixing the water and oil, that was with a 440-528 and my 200 hp shot poor tune. That was about 8 years ago, I have not run the bottle since, we live and learn.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2456527
02/24/18 04:34 AM
02/24/18 04:34 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I have split one through the mains and up into the bores mixing the water and oil, that was with a 440-528 and my 200 hp shot poor tune. That was about 8 years ago, I have not run the bottle since, we live and learn. Quitter! I don't care how many parts I sacrifice to the god of speed, they will pry that nitrous button from my cold dead fingers!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2456529
02/24/18 05:08 AM
02/24/18 05:08 AM
ozymaxwedge
Australia
Hahahahaha You go hard Billy, I'll go aftermarket block and procharger one day, after I rob the bank.
[Re: BigHemiVegas]
#2456607
02/24/18 12:26 PM
02/24/18 12:26 PM
Posts: 4,206 New York
polyspheric
New York
Keep those positive comments coming. NOT!!!!
Boffin Emeritus
[Re: BigHemiVegas]
#2456648
02/24/18 01:56 PM
02/24/18 01:56 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Not mine and I don't remember where I found it but here it is for your viewing pleasure.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: Digger73]
#2456726
02/24/18 04:11 PM
02/24/18 04:11 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
When it comes to decision making on race parts or hot street car parts I always think of the worst case scenario, do I really want to run over the engine parts above 100 MPH Not me now Been there done that way to many times Be safe, buy good parts and pray they don't fail at speed that can hurt you and the car
[Re: BigHemiVegas]
#2456731
02/24/18 04:23 PM
02/24/18 04:23 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I prefer to use the best parts I can that are up to the task, or even overkill for what we are doing. Properly put together, maintained, kept fresh, and hopefully, live a long productive life. I'm definitely not in the "build, run it till it blows, rinse, repeat" crowd. I'm weird like that.
[Re: CMcAllister]
#2456744
02/24/18 04:38 PM
02/24/18 04:38 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Properly put together, maintained, kept fresh, and hopefully, live a long productive life. You are not alone...
[Re: CMcAllister]
#2456895
02/24/18 07:41 PM
02/24/18 07:41 PM
Posts: 4,070 Mo.
racerx
Mo.
I prefer to use the best parts I can that are up to the task, or even overkill for what we are doing. Properly put together, maintained, kept fresh, and hopefully, live a long productive life. I'm definitely not in the "build, run it till it blows, rinse, repeat" crowd. I'm weird like that. this is how I think also.
[Re: racerx]
#2456980
02/24/18 10:35 PM
02/24/18 10:35 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
650-700 HP. looks like the limit. others did better, others Not so much! take the advice. if not good luck. Remember you can only become a millionaire in Drag racing if you start out as a Billionaire!
Hell Hath No Fury Like Mine
[Re: dvw]
#2457432
02/25/18 06:55 PM
02/25/18 06:55 PM
Posts: 287 PA
Harry's Taxi 2
PA
Mine broke at about 200 passes, 6500 max, aluminum caps. Dynoed at 657hp. Took the crank, 4 rods/pistons, 8 push rods and valves. Doug What cubic inch? cyl.heads?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
