Re: Anybody have a good how to source on rebuilding 833 4speed
[Re: BigHemiVegas]
#2455743
02/22/18 06:37 PM
02/22/18 06:37 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
You can make your own tools if you are creative. You could re-build one without any special tool but that would involve some questionable hammer and punch operations. I've seen a guy pound the mainshaft on a railroad tie to remove the bearing then whack it back home with a section of black pipe at the track A factory shop manual is a good tool to start with because it shows what some of the factory tools look like. Don't know if anybody has done a Youtube video yet I was going to make a video years ago but with the sue-happy people out there if something went wrong I would be the one to blame Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: hemi71x]
#2455820
02/22/18 09:15 PM
02/22/18 09:15 PM
Posts: 50 Where else?
BigHemiVegas
Where else?
Ya, the factory service manual. Everything you need to know. I already said that I didnt want to buy any expensive factory like tools like the service manual probably wants you to buy ALOT of.
[Re: fourgearsavoy]
#2455821
02/22/18 09:17 PM
02/22/18 09:17 PM
BigHemiVegas
Where else?
You can make your own tools if you are creative. You could re-build one without any special tool but that would involve some questionable hammer and punch operations. I've seen a guy pound the mainshaft on a railroad tie to remove the bearing then whack it back home with a section of black pipe at the track A factory shop manual is a good tool to start with because it shows what some of the factory tools look like. Don't know if anybody has done a Youtube video yet I was going to make a video years ago but with the sue-happy people out there if something went wrong I would be the one to blame Gus A how to tech video would have been awesome.
[Re: BigHemiVegas]
#2455860
02/22/18 10:43 PM
02/22/18 10:43 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
[Re: BigHemiVegas]
#2455929
02/23/18 01:10 AM
02/23/18 01:10 AM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
Ya, the factory service manual. Everything you need to know. I already said that I didnt want to buy any expensive factory like tools like the service manual probably wants you to buy ALOT of. A pair of Lock ring pliers is mandatory no matter what but those apparently fall under the special fancy expensive tool exclusion clause because that pesky FSM does tell you to use them. The fsm is $20 or even less on ebay and the wealth of knowledge it contains is priceless. The fsm does reference and call out using the special service tools but it also provides pictures of the tools and most can be substituted with other more common shop tools. As mentioned already it also provides the specs and directions on how things come apart and go back together.
[Re: ScottSmith_Harms]
#2455931
02/23/18 01:11 AM
02/23/18 01:11 AM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
I had Brewers rebuild two of them for me. They came out looking brand new! I'm glad I didn't take it on myself as they found multiple items in each that required replacement parts beyond what a typical freshen up requires. Jamie Passon is also just as great, he restored my 3 speed manual trans, you cant go wrong with either vendor. Agree, way back when I rebuilt one on my own, Had a lot of problem telling what to replace looking at the wear. Ending up taking it apart a 2nd time to replace some of the bigger pieces to get it right.
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: BigHemiVegas]
#2455942
02/23/18 01:29 AM
02/23/18 01:29 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I've seen a guy pound the mainshaft on a railroad tie to remove the bearing then whack it back home with a section of black pipe at the track That works a lot better than it sounds. And it can be reinstalled the same way you get it off - no black pipe necessary. You just need to get the bearings started square on the shafts. Works on both the tailstock and the input shaft. I bought the "special pliers" 40 some years ago at Sears. I bet you could find them on Ebay cheap. I made a tool to pop out the reverse shaft. A solid piece of barstock with a 90 degree bend. Long enough that the bend comes out at the end of the case opening. Used like a lever, the case edge acts as the fulcrum - you tap the end with a mallet and it drives out the shaft (which isn't terribly tight so there is no damage to the case). Any tranny shop will press the tailstock bushing in and install the seal with the proper tools for a couple of bucks.
[Re: Stanton]
#2456074
02/23/18 12:35 PM
02/23/18 12:35 PM
Posts: 356 NE
moparpoolman
NE
[Re: BigHemiVegas]
#2456483
02/24/18 02:09 AM
02/24/18 02:09 AM
Posts: 5,439 So Cal
Sinitro
So Cal
There are many internal parts of the A833.. We have had both Wayne @ Brewers & Jamie @ Passon rebuild transmissions for me, they have all the replacement parts and many years of experience rebuilding these. I just pay them to do it, even if I did take it on myself I would be pretty pissed if I had to take the transmission back out for some oversight.. I like to do many things myself but I leave this task to the experts. Besides they are both great Mopar guys.. Just my $0.02...
#2456493
02/24/18 02:18 AM
02/24/18 02:18 AM
BigHemiVegas
Where else?
I had Brewers rebuild two of them for me. They came out looking brand new! I'm glad I didn't take it on myself as they found multiple items in each that required replacement parts beyond what a typical freshen up requires. Jamie Passon is also just as great, he restored my 3 speed manual trans, you cant go wrong with either vendor. When did you have them rebuild and how much did they approximately charge for a rebuild of just one transmission?
[Re: BigHemiVegas]
#2456568
02/24/18 10:41 AM
02/24/18 10:41 AM
Posts: 356 NE
moparpoolman
NE
I had Brewers rebuild two of them for me. They came out looking brand new! I'm glad I didn't take it on myself as they found multiple items in each that required replacement parts beyond what a typical freshen up requires. Jamie Passon is also just as great, he restored my 3 speed manual trans, you cant go wrong with either vendor. When did you have them rebuild and how much did they approximately charge for a rebuild of just one transmission? The ad in MCG for Brewers reads: rebuild service $395 plus parts. http://www.brewersperformance.com/
[Re: BigHemiVegas]
#2457721
02/26/18 02:53 AM
02/26/18 02:53 AM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
When I was racing my Challenger hard with a Doug Nash internal Hemi four speed I bought the snap ring tool off Gray Tools. Number is B 684 and still says $4.99 on them. I liked them a little better than the Sears pliers but both are good. If you get cold feet Pasion and Brewers are good go to people.
1971 HEMI E BODY REGISTRY
