Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2454174
02/19/18 10:24 PM
02/19/18 10:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That is the 1970 chart as mentioned above.
It appears to have been stolen & modified though........
For the record, no one has permission to take images from HH, let alone modify them. twocents
Re: 71 340 e-body diff [Re: VCODE] #2454204
02/19/18 10:54 PM
02/19/18 10:54 PM
New Jersey Bada Bing
bremotorsports Offline
Bob,
Broadcast Sheet Axle Code 015
ALLEGEDLY, Code 015, at least as far as info I have seen to this point, indicates that for 71 E-Body with 3.23 standard axle, with 11" rear brakes and 7260 u-joints (both of which I have) shows the spec requires the 1-7/8" 489 diff. Sorry to disappoint any previously published info!!! Also, the date codes on the gearset are dead on for my car, and the diff assembly date (2/9/71) AND the ratio (3.23) are STAMPED DIRECTLY INTO THE DIFF CASE. No tag under and mounting nut.
I will also state without question that my car was 100 % untouched prior to my acquisition, as verified by conversation with the original owner, as well as my observations during disassembly.
Bill Rolik
Re: 71 340 e-body diff [Re: bremotorsports] #2454283
02/20/18 12:00 AM
02/20/18 12:00 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Originally Posted By bremotorsports
Bob,
Bill Rolik
Thanks Bill,
The info for my 014 is wrong in the white book listing it as a 3:55sg but the broadcast sheet list it as a 3:23 open
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 71 340 e-body diff [Re: 6bblgt] #2454437
02/20/18 08:56 AM
02/20/18 08:56 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1971 E-Body:
the "014" axle is a 741 case 7260 pinion w/3.23 ratio OPEN & 10" brakes
the "015" axle is a 741 case 7260 pinion w/3.23 ratio OPEN & 11" brakes
the "016" axle is a 489 case 7290 pinion w/3.23 ratio OPEN & 10" brakes
the "017" axle is a 489 case 7290 pinion w/3.23 ratio Sure-Grip & 10" brakes
the "018" axle is a 489 case 7290 pinion w/3.23 ratio OPEN & 11" brakes
the "019" axle is a 489 case 7290 pinion w/3.23 ratio Sure-Grip & 11" brakes
Re: 71 340 e-body diff [Re: 6bblgt] #2454452
02/20/18 10:54 AM
02/20/18 10:54 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Originally Posted By 6bblgt
1971 E-Body:
Dan, your the man. That's what I been trying to figure out.
Exactly what I have. Thanks Bob
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2454738
02/20/18 08:18 PM
02/20/18 08:18 PM
Chicago Blackhawks
hemicar1971 Online content
hemicar1971  Online Content
Chicago Blackhawks
Were does 101 on the broadcast sheet of a 1971 Challenger fit into the list. There must be more to the list and this 101 could be a 8 3/4 likely open either 741 or 489 case with 10 inch drums and 276 gears.
Re: 71 340 e-body diff [Re: 6bblgt] #2454760
02/20/18 09:17 PM
02/20/18 09:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1971 E-Body:
the "101" axle is a 741 case 7260 pinion w/2.76 ratio OPEN & 10" brakes
Re: 71 340 e-body diff [Re: 6bblgt] #2454836
02/20/18 11:21 PM
02/20/18 11:21 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
1971 E-Body:
So what is the trigger between getting a "015" vs. a "018" - my 71 340 Challenger is a 4 speed and Bill's 71 cuda 340 is an automatic yet we both have "015" ????
confused
Re: 71 340 e-body diff [Re: Morty426] #2454970
02/21/18 05:35 AM
02/21/18 05:35 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
next someone will want to know WHY? some '71s with disc brakes have 11" rear drums realcrazy
I'll take a look & see what I can find biggrin
Re: 71 340 e-body diff [Re: Morty426] #2454975
02/21/18 06:56 AM
02/21/18 06:56 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
for 1971 E-body 3.23:1 OPEN 8-3/4" rear axle - it looks like it is as simple as small block VS. big block (can't confirm where the 383 2bbl ends up?)
10" brakes = "014" (318 & 340) 741 VS. "016" (383 4bbl, 6bbl, HEMI) 489
11" brakes = "015" (318 & 340) 741 VS. "018" (383 4bbl, 6bbl, HEMI) 489
Re: 71 340 e-body diff [Re: 6bblgt] #2455075
02/21/18 01:59 PM
02/21/18 01:59 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Cool. That makes sense.
Now why did some disk brake cars get 11" rear brakes?
Re: 71 340 e-body diff [Re: Alaskan_TA] #2455472
02/22/18 05:01 AM
02/22/18 05:01 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Let me get this straight, you "steal" it from Chrysler, put your website watermark on it so it's yours? Oh Please, take your ball and go home.
Re: 71 340 e-body diff [Re: HEMICUDA] #2455570
02/22/18 01:17 PM
02/22/18 01:17 PM
WV
Little Detroit Offline
WV
get em mike
Re: 71 340 e-body diff [Re: HEMICUDA] #2455623
02/22/18 02:47 PM
02/22/18 02:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Funny how that works...
Re: 71 340 e-body diff [Re: RSNOMO] #2455853
02/22/18 10:20 PM
02/22/18 10:20 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
71 340 Cuda, auto 3/31 SPD
015: on broadcast
G015: stenciled on housing
741 carrier
7260 u joints.
