Page 5 of 7 1 2 3 4 5 6 7
Re: 470 dyno test article [Re: AndyF] #2454653
02/20/18 05:03 PM
02/20/18 05:03 PM
AndyF Online content OP
AndyF  Online Content OP
Haven't thought about it much. Wouldn't need to be very big, 0.020 should work but holes that small can get plugged up with any RTV that is floating around in the oil so it isn't a perfect solution.
Re: 470 dyno test article [Re: AndyF] #2454829
02/20/18 11:02 PM
02/20/18 11:02 PM
Sounds like the QRI lobe wasn't the best choice for this engine. Billy G. at Comp says the QRI lobes are designed for a smaller journal cam and with a Mopar large journal cam I would have better results with a DGO or LRW lobe. Which are lobes I've never heard of and are not in the master lobe catalog. Mr. G was kind enough to send me the new lobes so I'll attach them here. Just in case anyone feels the need to have the latest and greatest solid roller lobes.
Attached PDF document
Re: 470 dyno test article [Re: AndyF] #2454877
02/21/18 12:40 AM
02/21/18 12:40 AM
Texas
RustyM Offline
RustyM  Offline
Texas
Thanks Andy.
Guess its "onward" on cam choices for that 470.
you test- we learn.
Re: 470 dyno test article [Re: AndyF] #2455046
02/21/18 01:05 PM
02/21/18 01:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I think there might be "some" gains to be had by (as Grumpy said in his 1975 SBC book) "fiddling with the cam".
But, the fact that the motor didn't respond at all to a pretty big swing in rocker ratio changes....... I don't think there's any "easy 25hp" to be gleaned from only swapping the cam at this point.
I'd be looking towards the EM builds for inspiration as far as the cam goes.
Btw...... Did you mess with the lash?
Re: 470 dyno test article [Re: AndyF] #2455093
02/21/18 02:39 PM
02/21/18 02:39 PM
We'll loosen up the lash and make some runs today.
Comp engineer said to tighten up the LSA until we run out of valve clearance. My calculations say we can go to a 104 LCA before we start to run out of room with the existing lobes.
Re: 470 dyno test article [Re: AndyF] #2455110
02/21/18 03:14 PM
02/21/18 03:14 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thats the test i would like to see results with. LSA.
Re: 470 dyno test article [Re: mopar dave] #2455149
02/21/18 04:27 PM
02/21/18 04:27 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You can probably find a good number of LSA-type tests searching online. No real mystery, other than making sure the LSA, duration & lift actually suit the combination.
Well, maybe it's a mystery to a lot of people, still. haha
Re: 470 dyno test article [Re: BradH] #2455236
02/21/18 07:46 PM
02/21/18 07:46 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yes you can. I have read a few. Seems 108 works pretty good on a small block. I would like to see first hand what Andy finds with that BB.
Re: 470 dyno test article [Re: AndyF] #2455562
02/22/18 01:03 PM
02/22/18 01:03 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Were the 270 heads otb or ported?
Re: 470 dyno test article [Re: AndyF] #2455567
02/22/18 01:12 PM
02/22/18 01:12 PM
TF 270 heads have out of the box ports and valve job. The springs have been changed and we did a little bit of machine work so 7/16 inch pushrods would fit.
Re: 470 dyno test article [Re: AndyF] #2455582
02/22/18 01:40 PM
02/22/18 01:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
TF 270's are fully ported OOTB.
Sure, some may be porting them more, but there are no "unported" TF 270's.
Re: 470 dyno test article [Re: AndyF] #2455590
02/22/18 01:51 PM
02/22/18 01:51 PM
Opening up the lash by 0.005 didn't change the peak power but it did add a little big of area under the curve. So I'm fairly well convinced that this particular cam wasn't what the engine needed. Maybe just a little too big.
It worked better advanced 4 degrees and with looser lash. To be fair, I did not do a lash test with teh 264/268 cam and I never tried anything other than 4 degrees advanced so I don't know if that cam is "perfect" or just closer to the target.
Re: 470 dyno test article [Re: AndyF] #2455594
02/22/18 01:57 PM
02/22/18 01:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
So, peak to peak, what was the difference between the two cams?
Re: 470 dyno test article [Re: mopar dave] #2455598
02/22/18 02:08 PM
02/22/18 02:08 PM
BradH Offline
BradH  Offline
... Seems 108 works pretty good on a small block.
Not trying to bust your chops, but 108 works where 108 is the right LSA for the combination, regardless of small block, big block, or whatever. Four of my last five BB cams have all been 108, because that's been a good choice for those combinations. If I made significant changes, I'd expect the LSA and/or duration might need to change, too. I've got a nice 109 LSA solid roller that I never tried because I didn't have the right rocker ratios on hand to show its true potential. That cam grinder wanted to put it on 110, but we split the difference on his preference for 110 and mine for 108.
... I would like to see first hand what Andy finds with that BB.
I can't ready Andy's mind (nor my wife's, even though she thinks I'm supposed to be able to), but I suspect anyone who wants to send him a $1000 to offset parts / teardown / dyno expenses might "influence" what he's interested or willing to test. I've got enough first-hand experience now from multiple dyno sessions to know that stuff gets spendy fast, especially if it turns into more of an R&D session than a straight test & tune of a single combination.
Re: 470 dyno test article [Re: fast68plymouth] #2455614
02/22/18 02:33 PM
02/22/18 02:33 PM
Turns out I don't have a clean A to B test with the same exact parts on both engine due to the problems I had with the vacuum pump. I wasn't able to run the QRI cam with a vacuum pump since I had issues with it so all of my current testing is with breathers. The engine is making right around 750 hp with the QRI cam using breathers.
I made 775 hp with the HXL cam using a vacuum pump and Wilson Indy. I made 745 hp with the HXL cam using breathers but with the M1 Wilson intake. (std port intake) I never tested the HXL cam with breathers and the Indy Wilson intake so I don't have that as a baseline.
My guess is that the HXL cam with breathers and the Indy Wilson intake would hit 755 or 760 hp in an A to B test but I wouldn't be surprised to be wrong.
Another thing is the weather. The last few days have had cold air so the correction factor is negative. Even thought the correction factor is only a few percent different than the previous tests, that is enough difference to throw some doubt on the comparison.
Re: 470 dyno test article [Re: BradH] #2455624
02/22/18 02:47 PM
02/22/18 02:47 PM
Yeah no doubt about that. I'm fortunate to be in a position where I have the resources to do this type of testing but still there are limits. I might have the time to dink around with engine testing but people around me don't have the time so I have to respectful of them. The guy who runs the dyno has to make a living and he can't just play engines with me all day since he needs to get work out the door in order to feed his family. Given that, I can only squeak in some dyno testing "fun" about 4 or 5 times a year. So I have to pick and choose what I'll test.
Re: 470 dyno test article [Re: AndyF] #2455636
02/22/18 02:57 PM
02/22/18 02:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
Did you A/B the vacuum pump last time, so you have a pretty good idea on what that was worth?
Sounds like you're thinking 10-15hp.
Re: 470 dyno test article [Re: AndyF] #2455673
02/22/18 04:02 PM
02/22/18 04:02 PM
Yes, the vacuum pump was worth 15 hp and the Indy Wilson was worth 15 hp. The M1 with breathers was 745, then went to 760 with the vacuum pump and then went to 775 with the Indy intake.
I'll attach a chart with the lash test. There is enough "noise" in the testing results that it is hard to see a clear change but my guess is that the looser lash is making a little more area under the curve. So the cam might be a little too big.
20chart.pdf (73 downloads)
Re: 470 dyno test article [Re: BradH] #2455702
02/22/18 04:57 PM
02/22/18 04:57 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Brad, it sounded to me that Andy was going to experiment with lobe sep angles. I did not suggest he do that or tell him too. My comment was about my curiosity of what he finds in that test. No one has to remind me of the expenses of this hobby as i understand that as well. My 410 that came apart on the dyno was a real good education of the expenses of this hobby. About a $5000 education.
Re: 470 dyno test article [Re: BradH] #2455710
02/22/18 05:10 PM
02/22/18 05:10 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
David Vizard has a graph for selecting lobe sep angles. He says its the best way to do it as he finds more power in big blocks than most anyone else. I have never seen anyone use it. Looking at his graph shows my 511 would need a lob sep of 100*. I have never seen anyone use a cam with those kind of lobe sep angles. Anyone know if Vizards gragh is BS or is there some validity to it. I am assuming his engines are race only.
