Re: '71 Roadrunner Air Grabber
[Re: intruder71]
#2455900
02/23/18 12:11 AM
02/23/18 12:11 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
easiest thing comes to mind is a window lift motor off a ricer. 12 volt and something you could find in pull a part. get a switch and a pigtail off the same car.Unsure of what make would have a usable mechanism and not a cable or tape drive...but even those could work.Good luck bud!
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: intruder71]
#2456038
02/23/18 10:55 AM
02/23/18 10:55 AM
Posts: 1,845 Sault Ste. Marie, Ontario, Can...
moparmike1
I recently bought a 71 RR with a 415 stroker motor and dual quads. The guts of the Air Grabber were removed to make room for the 415 Stroker. The Air Grabber is held in the "up" position with a few screws that I can remove. I'd like to make the Air Grabber functional with a small servo motor. Does anyone have any ideas on how to attach a small electric or hydraulic motor with a switch inside the car so that I can raise/lower the AG? Thanks. If you're on Facebook, join the '71 - 74 roadrunner/charger owners group' page. There is a post from Ronny Conklin on February 22, 2018, describing exactly what you're looking for. He did it with a remote control car servo. Mike.
[Re: intruder71]
#2456217
02/23/18 04:14 PM
02/23/18 04:14 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I know you're looking for a servo, but why not just hook up the air grabber the way the factory did???? I mean, because you're motor is a stroker doesn't make it any larger on the outside.
Unless I'm missing something (?) you could just put the air grabber stuff back in & have it work like the factory intended. The ONLY thing I would be concerned about is the carb/carb spacing on the intake manifold & the overall height of the intake.
Your hood closes, right? The air grabber box is in there, right? If not, then "maybe" consider an old 413 dual quad cast iron intake or an Offenhauser low-rise dual quad intake.
The only big question I have is, "Will a hemi dual quad air grabber air cleaner fit my dual quad carbs?" I thought about running a dual quad on my '70 Roadrunner many times, but never had a hemi air cleaner base (or knew the carb spacing) to check. As long as the hemi air grabber base fits your carbs & your hood closes, you can run a factory air grabber setup.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2456475
02/24/18 01:49 AM
02/24/18 01:49 AM
Sixgun
Western Washington
The factory spacing for the carters is real close together, too close for holley 600's. Depends on your DQ manifold, but most of those I have seen were set up with the wider spacing to accept either carter, (eddy) or holley with the side hung bowls (600 single feed style). I have the stage 5 on my 572 and butchered a repop 'glass AG base and mated it with two cheap aluminum drop bases from jegs. FHO has a real nice metal (IIRC) base for stage 5 intake but it's like 550.
