71 340 e-body diff #2453622
02/18/18 09:02 PM
02/18/18 09:02 PM
BLACKHEMIRR Offline OP
Does anyone know what 8 3/4 case a 340 auto car would have come with if it was a 3.23? Could it have come with a 741 case, or would it have been a 489?
Thanks in advance
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453662
02/18/18 10:47 PM
02/18/18 10:47 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
pretty sure it would have been 489
741 and 742 cases were older models
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453766
02/19/18 02:27 AM
02/19/18 02:27 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have two 1970 741 cars, behind a 318 & 383.
If you have a broadcast sheet for it, what is coded?
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453775
02/19/18 02:58 AM
02/19/18 02:58 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
should be a 489
Re: 71 340 e-body diff [Re: Morty426] #2453807
02/19/18 07:15 AM
02/19/18 07:15 AM
I don't have a broadcast sheet unfortunately, but the dates look right anyway. The car is a H1B402... vin, and the 741 gears are dated April of 1971. It looks like the small u-joint driveshaft that's in it is original.
Re: 71 340 e-body diff [Re: Alaskan_TA] #2453820
02/19/18 10:51 AM
02/19/18 10:51 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
My 71 340 Cuda with 3:23 open has a 741
Not sure if it is right or wrong yet.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453865
02/19/18 12:24 PM
02/19/18 12:24 PM
Akron, ohio
76orangewagon Offline
Akron, ohio
My April 30 built 340 Cuda is coded for 019 Axle assembly on my build sheet which breaks down to a E body 3.23 S/G with 11 drum brakes 8.75 Rear end and a 1 7/8" Pinion and 7290 Yoke. A 1 7/8" pinion only came in 489 case.
Re: 71 340 e-body diff [Re: 76orangewagon] #2453891
02/19/18 01:08 PM
02/19/18 01:08 PM
Thanks for all of your replies. I wonder if it's possible that the sure-grip cars got the 489 case, and the open cars got the 741's?
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453911
02/19/18 01:49 PM
02/19/18 01:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have a 71 challenger r/t N-code 383 HP with 3.23 open... 489 case
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453927
02/19/18 02:23 PM
02/19/18 02:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I know that the 741 was still in use for 1970 models in addition to the 489.
There is a chart with the 1970 information at http://www.hamtramck-historical.com/images/TSBs/1970/D70-3-2%20page4.jpg
My 1970 Valiant has a 3.23 741 while my 1970 Fury has a 3.23 489 & both are open with the small yoke.
Both are called out on their broadcast sheets.
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453930
02/19/18 02:31 PM
02/19/18 02:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I know a low mile 71 Demon 340 3.23 open, LA plant, with 741 case.
Re: 71 340 e-body diff [Re: Alaskan_TA] #2453966
02/19/18 03:46 PM
02/19/18 03:46 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Do you have a chart for 71?
My 71 340 has axle code 015 - should be a 3.23 open
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453969
02/19/18 03:52 PM
02/19/18 03:52 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I have a Nov.5 1970 SPD, build 383 1971 Cuda automatic that came with a 489 sure grip. One other in my family had a 1971 Cuda built in Dec. of 1970 that had a 489 Sure grip.
1971 HEMI E BODY REGISTRY
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2453970
02/19/18 03:53 PM
02/19/18 03:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If anyone has a 1971 chart, I would love to see it also!
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2454028
02/19/18 05:37 PM
02/19/18 05:37 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
71 340, D32, H51, SPD 601, axle code 017, 3.23 SG, 10" brakes, 489 case, 7290 u-joint
Re: 71 340 e-body diff [Re: JRepucci] #2454052
02/19/18 06:38 PM
02/19/18 06:38 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
eliminating the A-body axle assemblies
1970 E-Body:
the "048" is a 741 w/2.76 ratio OPEN & 10" brakes
the "100" is a 741 w/3.23 ratio OPEN & 10" brakes
the "341" is a 741 w/3.23 ratio OPEN & 11" brakes
the "049" is a 489 w/3.23 ratio OPEN & 10" brakes
the "073" is a 489 w/3.23 ratio OPEN & 11" brakes
there are a number (for use in "axle packages") that do not have an "*" for sure-grip
anyone know what the "S" & "L" represent by the pinion diameter?
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2454070
02/19/18 06:58 PM
02/19/18 06:58 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
S = Small 1 3/8 = 741
L = Large 1 7/8 = 489
Another way to tell 489 is the spacer column. 489 all had collapsible spacer, not shim.
Re: 71 340 e-body diff [Re: NANKET] #2454120
02/19/18 08:41 PM
02/19/18 08:41 PM
New Jersey Bada Bing
bremotorsports Offline
My 71 340 Cuda Convertible
BS27H1B344342
Automatic
I am 2nd titled owner. Original owner still with us.
741 Case, 3.23 Non-Sure Grip, 7260 U-joints
Bill Rolik
Re: 71 340 e-body diff [Re: bremotorsports] #2454123
02/19/18 08:52 PM
02/19/18 08:52 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
BS27H1B344342
Automatic
Bill Rolik
Bill, what is your Broadcast sheet Assy #
Bob
Re: 71 340 e-body diff [Re: BLACKHEMIRR] #2454159
02/19/18 10:05 PM
02/19/18 10:05 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The S and L I would think it stands for stem diameter of the gears, Small or Large and refer to 1 3/4 for small and 1 7/8 large.
6bblgt is that chart for 1971 E Bodies. Looking at one 71 E Body BCS, here are some numbers under fourth line under axle 101, Line three under D axle 51.
