BB engine brackets
#2453374
02/18/18 10:03 AM
02/18/18 10:03 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
A friend of mine is working on reproduce locally ( for his 73 Chally ) these engine mounts brackets. Supossely each side got its own engine mount bracket BUT working just on one of them, found this one fits the same on both sides.
why then 2 differents for these mounting brackets ?
( pics coming )
Re: BB engine brackets
[Re: NachoRT74]
#2453377
02/18/18 10:18 AM
02/18/18 10:18 AM
NachoRT74
Valencia, España
these are the first test and fitting test. He got both sides as "template" from a friend but found there is not really a difference trying to fit any side to the opposite side.
Metal is thicker than the originals.
We are aware about the spacer welded to one of the engine mounts ( for whatever reason ) on the lower mount bolt. But talking just about fitting.
[Re: NachoRT74]
#2453380
02/18/18 10:25 AM
02/18/18 10:25 AM
NachoRT74
Valencia, España
I guess maybe the diff ofset for the engine mounts studs could be a reason ? but then... is there another reason ? originals are both diff shape somehow
[Re: NachoRT74]
#2453402
02/18/18 12:04 PM
02/18/18 12:04 PM
NachoRT74
Valencia, España
I can see the diff shapes, but can't get the reason for that.
440 source states the ones they are selling are the same but just the spacer to mark the diff side.... aside the mount offset provissions, since mount is the same for both sides but turned around ( hence the offset holes made diff )
http://store.440source.com/Engine-Support-Brackets-66-72B-66-73C-70-74E/productinfo/119%2D1000/
[Re: NachoRT74]
#2453403
02/18/18 12:05 PM
02/18/18 12:05 PM
NachoRT74
Valencia, España
I guess the driver side gets that "bed" on bracket where the mount goes to hold better the engine torque direction ? helping to keep the position for the mount against the bracket
[Re: NachoRT74]
#2453836
02/19/18 11:26 AM
02/19/18 11:26 AM
Posts: 15,487 Florida
scratchnfotraction
I just removed a driver side mount from a 67 c-body 440/727 I drug home this weekend.
the driver side mount had 2 short bolts and 1 long bolt through the support tube welded to mount.
no block lug. nut on long bolt is close to backside of oil pump on driver side. tube/long bolt supports mount from twisting as engine lifts from torque.
they seem to be they same as in the pics.
free if someone needs a set.
[Re: scratchnfotraction]
#2454256
02/19/18 11:30 PM
02/19/18 11:30 PM
Posts: 2,046 ky.
kenworth_goose
ky.
free if someone needs a set. I'm going to build some out of flat stock, also doing the big block truck brackets. I could use a set to make a pattern from. I'll send them back to you when I'm finished. Or sent them on to someone that needs them if you want.
