Power Drum Brakes: Pedal Goes to Floor? #2453305
02/18/18 01:24 AM
02/18/18 01:24 AM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
69 Charger RT, new MC and stock booster/prop valve, replaced front lines during engine rebuild. Bench bled MC, then bled RR, LR, RF, LF several times until no air bubbles (Dot4). Pedal good until engine start at which point pedal goes to floor. Stock engine rebuild so plenty of vacuum for booster.
Did it again, incl bench bleed, same result. No leaks apparent, new wheel cylinders. Would seem to be booster related as that is the only brake sys component activated at startup, although IIRC a bad booster typically causes a hard pedal.
Suggestions?
Re: Power Drum Brakes: Pedal Goes to Floor? [Re: 70runner] #2453308
02/18/18 01:33 AM
02/18/18 01:33 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Bled to no air bubbles..but was the pedal hard and steady?
Re: Power Drum Brakes: Pedal Goes to Floor? [Re: 70runner] #2453320
02/18/18 02:03 AM
02/18/18 02:03 AM
70runner Offline OP
70runner  Offline OP
Yes, after bleeding, pedal was hard and steady...until I start the engine.
Re: Power Drum Brakes: Pedal Goes to Floor? [Re: 70runner] #2453321
02/18/18 02:04 AM
02/18/18 02:04 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
air gap between master and booster?, should be .020 to .060 max, too much and pedal goes to the floor...
Re: Power Drum Brakes: Pedal Goes to Floor? [Re: 70runner] #2453330
02/18/18 02:26 AM
02/18/18 02:26 AM
70runner Offline OP
70runner  Offline OP
I'll check it out, THX!
Re: Power Drum Brakes: Pedal Goes to Floor? [Re: 70runner] #2453332
02/18/18 02:31 AM
02/18/18 02:31 AM
an engine valvetrain pushrod makes an easy tool to measure the distance out to the MC flange then you want the booster pushrod .020" less than that distance protruding out from the booster flange.
Re: Power Drum Brakes: Pedal Goes to Floor? [Re: RapidRobert] #2453362
02/18/18 04:34 AM
02/18/18 04:34 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
if you make the pushrod too long, brakes will be applied anytime the engine starts
