97 Dakota transfer case ? #2452885
02/17/18 12:57 AM
02/17/18 12:57 AM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
My 97 Dakota with 318, 4x4, 230,000 miles has developed a loud clunk in the driveline while driving. It will clunk and actually shake the truck a little. Could this be the transfer case going bad? The transmission shifts fine with no slipping and has clean, red fluid. Transfer case oil level is full. This does it in straight line driving, not in turns. Thanks for any help.
Re: 97 Dakota transfer case ? [Re: 340Scamp] #2452969
02/17/18 10:37 AM
02/17/18 10:37 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
check all u joints and axles
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 97 Dakota transfer case ? [Re: 340Scamp] #2453798
02/19/18 05:02 AM
02/19/18 05:02 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 1st thing I would look at would be to see if the rear pinion nut has backed off. Then the ujoints, axle bearings and motor/trans mounts. Then see if any of the body mounts are still holding the body onto the frame. Gene
Re: 97 Dakota transfer case ? [Re: 340Scamp] #2453827
02/19/18 11:05 AM
02/19/18 11:05 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
What joints are in the front drive shaft? Some ifs front driveshafts use cv. Joints on them and when they wear out the symptoms are like a clunk, crunch, binding deal. Make you think you have teeth missing on the ring gear. Easy Enough to pull The front driveshaft.
Re: 97 Dakota transfer case ? [Re: JAMESDART] #2453872
02/19/18 12:31 PM
02/19/18 12:31 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
It isn't a steady clunk, it only does it every now & then, maybe only 2 or 3 times a day.
Re: 97 Dakota transfer case ? [Re: 340Scamp] #2454007
02/19/18 04:51 PM
02/19/18 04:51 PM
Guitar Jones Offline
Check the easy stuff first, don't go directly to the hard parts.
Start with a good visual inspection of the u joints, driveshafts, mounts, mounting bolts and such.
