Re: Ritter Block
[Re: Thumperdart]
#2459628
03/01/18 10:48 PM
03/01/18 10:48 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
So one guy say's he thinks the aluminum XR2 will only go 4.1" bore. And everyone repeats it.
There is no reason this block in aluminum can't go at least 4.185". After all the other aluminum blocks with this bore space go 4.185".
Re: Ritter Block
[Re: WHITEDART]
#2461886
03/06/18 05:34 AM
03/06/18 05:34 AM
Posts: 6,142 Melbourne , Australia
LA360
And for those that know about honing They made a substantial investment (around $100K) in their honing equipment. Definitely a higher end machine shop I think you meant to say hone head and diamonds .. and actually I think that was only for the old head and stones. They have substantially better stuff than that now.. I think if you have a Target temperature that you can operate the Motor Inn he can hone the block at that temperature.. Yes,I should have been more specific, or used a word like accessories :-p Unlike regular stones and honing heads, One head does one bore size. It all adds up rather quickly!
Alan Jones
Re: Ritter Block
[Re: Leon441]
#2461964
03/06/18 12:44 PM
03/06/18 12:44 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
There is no reason this block in aluminum can't go at least 4.185". After all the other aluminum blocks with this bore space go 4.185". the question that comes to mind.. is he referring to the block that is sleeved or unsleeved.. I know in the beginning he was selling unsleeved blocks and recommended people use the spray in liner.. I would imagine with a good quality sleeve maybe like a interlocking Darton set up you could get 4.200.+ but I have never physically seen an aluminum block
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
