Re: Victor or Trickflow heads most bang for the buck?
[Re: tex013]
#2446496
02/04/18 09:04 PM
02/04/18 09:04 PM
Posts: 31,088 Oregon
AndyF
Read the 270 articles that I've written and study the pictures. You'll see that I used standard offset rocker arms on the 270 heads and that I've used a standard port intake on the 270 heads.
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there. Andy , You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site Victors are listed as using S70015EVK which are .650 offset So do the 270s use non offset or offset ? Tex Not offset. S700115KE supposedly corrects geometry issues with the Trick Flos. Just bought a set. Thanks markz528 So you could possibly use the Crane standard rocker if geometry works ? I know it sounds like I am beating this to death BUT if I go this way I am looking at over $1300 of my quality Aussie dollars plus shipping . Tex Did you read the rocker arm article I wrote? I tried a bunch of different rocker arms on Trick Flow heads. There shouldn't be a lot of questions left after reading that article. I tried basically everything that is currently available.
[Re: Digger73]
#2446613
02/05/18 01:17 AM
02/05/18 01:17 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Andy , I am not being a smart ar$e . I have seen some of your rocker info re the 240 head and you said Cranes were fine . All I have seen on the 270 was your pictures/dyno test and use of offset high ratio ones. TrickFlow list a non offset rocker . markz528 also notes the listed rocker is not offset
Quote from Summit - Q: Do these heads run an offset rocker?? Asked by KEITH E on September 12, 2017 A: Thank you for your question. The Trick Flow Specialties TFS-61617801-C01 cylinder heads do not require an offset rocker arm. They use all factory-style big block Mopar shaft mount rockers. Summit Racing Answer - October 16, 2017
If you can link your rocker test , would be great . Someone's wires may be crossed .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Digger73]
#2446621
02/05/18 01:32 AM
02/05/18 01:32 AM
fast68plymouth
So. Burlington, Vt.
The 240's and 270's use the same rockers.
Std offset, like what you'd use on a stock head or RPM head.
[Re: tex013]
#2446627
02/05/18 01:43 AM
02/05/18 01:43 AM
AndyF
Tex
Go look at the TF270 articles and you'll see that I used the same exact rocker arms as on the TF240. Both the 240 and the 270 use standard offset rocker arms.
[Re: srunge55]
#2447141
02/05/18 11:06 PM
02/05/18 11:06 PM
dartman366
Mt. Vernon, Ohio
I used the valley plate for the 400 block. Its a nice quality part but there is a good gap between the plate and the head that needs to be filled with RTV. I think this part is only for the MW/270 head, the standard port/240 uses a valley pan. I used Andy's valley plate and bat wing gasket system and it works quite well with my TF 240's.
[Re: Digger73]
#2449304
02/09/18 11:00 PM
02/09/18 11:00 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Well I just ordered the Trick flow 270 heads. They should be here next week. Thanks everyone for the advise and suggestions. I am looking forward to getting my hands on these heads. Is there anything that I need to do before I bolt them on?
Thanks again,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: Digger73]
#2449323
02/09/18 11:35 PM
02/09/18 11:35 PM
tex013
Sydney,Australia
Thanks again,
Digger73 (Mike) Only thing i have read is check valve guide clearance , can be a little tight Tex
[Re: Digger73]
#2451482
02/14/18 12:31 AM
02/14/18 12:31 AM
Digger73
Portland, Oregon
Heads came today! They look AWESOME! I can't wait for the weekend to start installing them. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Digger73 (Mike)
[Re: Digger73]
#2451580
02/14/18 08:35 AM
02/14/18 08:35 AM
tex013
Sydney,Australia
Heads came today! They look AWESOME! I can't wait for the weekend to start installing them. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Digger73 (Mike) Look forward to your results . Please let us know which rocker setup you use and how they fit up . Plus of cause how they perform on your engine package Tex
[Re: Furys]
#2451581
02/14/18 08:37 AM
02/14/18 08:37 AM
tex013
Sydney,Australia
how can I get a set of those bat wing spacers andy makes Got mine through Mancini . Have to wait till June mid season winter break to fit them up Tex
[Re: New school]
#2739160
02/02/20 08:04 PM
02/02/20 08:04 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
When it comes to guys, gals now also, and drag racing there are several different types of guys, gals and racers. Some that will help and some that won't ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Some of those that will share info that have valid info, there are others that will share with you what they know but may not fully understand how to tell you useable information and their are some of those that will intentionally mislead you when you ask them for help ![rant rant](/ubbthreads/images/graemlins/custom/rant.gif) Be carful on who you use for information gathering ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Drag racing and private flying are very similar, neither one is getting bigger from growth and more racers and air plane owners and pilots ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
