990 pin #244995
03/06/09 03:02 PM
03/06/09 03:02 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
What for engines do you and can you build using a stock length 440 rod with a 990 pin size? Can you use these rods to make a typical 440? or are they more used for stroker kits? I can get a set of scat rods cheap but they are 990 pin size and didn't know what they are really used for.
Re: 990 pin [Re: DusterKid] #244996
03/06/09 04:11 PM
03/06/09 04:11 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Do you have pistons yet?
If you don't just order a set with that pin size
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 990 pin [Re: DemonDust] #244997
03/07/09 04:23 AM
03/07/09 04:23 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
It is just a lighter, more common pin diameter originally used in BB chevys. I am currently working on a .055 over 440, stock crank, h beam rod, JE pistons with .990 pins. I am sure some of the others can chime in, so here is a
