Damper removal HELP*^#!!! #2449780
02/10/18 09:35 PM
02/10/18 09:35 PM
Australia
O
ozymaxwedge Offline OP
O
Australia
Hey guys, trying to remove a damper/harmonic balancer, have tried 3 different pullers and bent or broken everything, this thing is stuck on good.
It is a Romac balancer on a close to new Scat crank.
Any help or idea's welcome, wasted 4 hours on it yesterday its driving me nuts.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449820
02/10/18 10:31 PM
02/10/18 10:31 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Did you remove the big bolt in the middle? grin
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449824
02/10/18 10:37 PM
02/10/18 10:37 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Dynamite always works good... smile
Just my $0.02.. wink
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449826
02/10/18 10:42 PM
02/10/18 10:42 PM
How about some heat on the inner hub from a hair dryer or heat gun shruggy scope twocents
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449845
02/10/18 11:10 PM
02/10/18 11:10 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
1) Your favorite penetrant, front and rear of the hub.
2) Your favorite puller (if any still remain) in firmly-moderate tension overnight.
3) A little more tension added in the morning along with a couple well-placed raps with a hammer and large pin on the hub at the crank.
4) Catch the damn damper.
Worked on a FD that refused to come off...
Old, tired, and sometimes broke down. Me, not my car...
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449848
02/10/18 11:13 PM
02/10/18 11:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I know some aftermarket balancers are a TIGHT fit. I would keep at it until you start pulling threads out of balancer. Screw those bolts deep in there. Never saw that kind of strippage yet.
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449850
02/10/18 11:17 PM
02/10/18 11:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
How about pics of the puller you are using?
Re: Damper removal HELP*^#!!! [Re: markz528] #2449871
02/11/18 12:04 AM
02/11/18 12:04 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m betting you are using an 8.00
Harbor Freight pulley puller instead of a good harmonic balancer install, puller tool. Once you use one you won’t go back.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449918
02/11/18 02:08 AM
02/11/18 02:08 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the local parts stores for loaner balancer puller. I know O'Reilly's loans tools. Put a deposit down and when you return it you get it back.
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449925
02/11/18 02:32 AM
02/11/18 02:32 AM
AndyF Offline
AndyF  Offline
You need a real damper pulley like this one. I made this from heat treated steel that is 1 inch thick.
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449959
02/11/18 05:49 AM
02/11/18 05:49 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Any feedback on the Jegs Universal remover/installer kit?
http://www.jegs.com/i/JEGS-Performance-Products/555/W89711/10002/-1
I bought one and it seems pretty nice, but I have not had to pull a really stuck damper with it?
As Shoozy said, soak it, put tension on it, tap it a bit, and let it sit overnight. Then repeat. If your going to trash the damper, hit it with some good heat from a torch.
On the aftermarket stuff (crank and/or damper), check the press fit of the damper to crank. According to my machine shop, it is fairly common to have to hone the damper a bit so it is not too tight? My ATI damper was honed at the machine shop to fit correctly. ATI says 0.002" for the aluminum hub units, and 0.0007" for steel. The Romac sheet on-line just notes 0.0005"?
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449966
02/11/18 07:29 AM
02/11/18 07:29 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Aftermarket crank and balancer.....it's always going to be over the top tight, either the crank snout should have been linished down a bit or the bore of the balancer should have been honed, do yourself a favour and measure the crank and get the balancer honed before reassembly.
Re: Damper removal HELP*^#!!! [Re: AndyF] #2449970
02/11/18 09:19 AM
02/11/18 09:19 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Now that's a puller. Sell any?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Damper removal HELP*^#!!! [Re: pittsburghracer] #2449981
02/11/18 11:12 AM
02/11/18 11:12 AM
Australia
O
O
Australia
That may be like the first one I broke but the next 2 pullers where 3/8 and 1/2 plate discs, only 3 bolt, bent them and snapped bolts.
A genuine 8 hours work but we finally got it.
I had a few old factory steel crank dampers so I cut the outer ring off, drilled out the 6 bolts, grabbed 6 x 5/16 ARP bolts and a mates power ram.
Some serious metal transfer between the two surface, crank will need machining and I will be using a different damper.
I'll post some pics tomorrow.
1971 Barracuda
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449982
02/11/18 11:13 AM
02/11/18 11:13 AM
Australia
O
O
Australia
P.S, Andy's puller would normally do the job but there is not a hope in hell that it would have worked on this job.
1971 Barracuda
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2449990
02/11/18 11:45 AM
02/11/18 11:45 AM
PA.
"Little"John
"Little"John
PA.
Trust me I have my share of cheap ones laying around. I finally had to buy one like the one in the Jegs link because I built a couple of Chevy engine and you can’t pull them on with the cheap azz bolt that GM uses to hold them on. It’s a very nice tool but it makes you stop and think and remember set up because it installs and removes. Do yourself a favor and use some anti-sieze on it when you put the next one on.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Damper removal HELP*^#!!! [Re: pittsburghracer] #2450181
02/11/18 05:57 PM
02/11/18 05:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Make sure you hone it out before you put it back on. I always put a light coat of slippery gear lube on it so it slides back om without galling. These Mopar dampers are always way tighter than they need to be twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2450211
02/11/18 06:51 PM
02/11/18 06:51 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
On my last two small block stroker builds I've used aftermarket dampers, both had to be honed to get the proper interference fit.
Re: Damper removal HELP*^#!!! [Re: justinp61] #2450345
02/11/18 10:45 PM
02/11/18 10:45 PM
going back together (FWIW) would some heat on the dampener/dry ice on the snout help?
Re: Damper removal HELP*^#!!! [Re: ozymaxwedge] #2450377
02/11/18 11:20 PM
02/11/18 11:20 PM
A good brand of antisieze is your friend on any new dampener, especially on Chevys grin
