How does oil get here? #2449777
02/10/18 09:31 PM
02/10/18 09:31 PM
IL
furious70 Offline OP
IL
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How does oil get here? [Re: furious70] #2449779
02/10/18 09:34 PM
02/10/18 09:34 PM
Minn
SportF Offline
SportF  Offline
Minn
That is probably gas. Slow leak, most evaporates, and that is what is left. Check screws, fittings on carb. Good luck.
Re: How does oil get here? [Re: furious70] #2449785
02/10/18 09:42 PM
02/10/18 09:42 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Check the throttle shaft for leaks.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: How does oil get here? [Re: furious70] #2449797
02/10/18 09:58 PM
02/10/18 09:58 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
If it's oil, it's likely coming up through the threads in the intake bolt.
Re: How does oil get here? [Re: Jim_Lusk] #2449827
02/10/18 10:44 PM
02/10/18 10:44 PM
iagree scope
Re: How does oil get here? [Re: furious70] #2449828
02/10/18 10:47 PM
02/10/18 10:47 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Bet it smells like gas.
Facts are stubborn things.
Re: How does oil get here? [Re: Jim_Lusk] #2449836
02/10/18 11:02 PM
02/10/18 11:02 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
This. Seen it many times. Put some liquid thread sealant on intake bolts.
Re: How does oil get here? [Re: furious70] #2449854
02/10/18 11:27 PM
02/10/18 11:27 PM
Maryland
MoparMike1974 Offline
Maryland
Very common issue. The oil seeps up through the intake bolt holes. I put some silicon on the threads.
Re: How does oil get here? [Re: furious70] #2449858
02/10/18 11:39 PM
02/10/18 11:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Teflon paste type sealer works the best on intake bolts.
Doug
Re: How does oil get here? [Re: furious70] #2449881
02/11/18 12:23 AM
02/11/18 12:23 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Looks like gasoline to me, and I see a trail leading down to it.
Re: How does oil get here? [Re: dvw] #2449960
02/11/18 05:53 AM
02/11/18 05:53 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Doug
iagree
If the intake bolts do not have the sealer, the oil can wick up the threads to the intake.
Re: How does oil get here? [Re: furious70] #2449986
02/11/18 11:37 AM
02/11/18 11:37 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I had same thing and it was accelerator pump gasket on Holley. Looks just like oil after most of the gas evaporates.
Re: How does oil get here? [Re: furious70] #2450051
02/11/18 02:06 PM
02/11/18 02:06 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Been twisting wrenches for over 50 years, mostly on Mopars. this is typically oil following the intake bolt threads up and pooling in the intake. A little sealer on the intake bolts is all you need.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: How does oil get here? [Re: Tempest] #2450170
02/11/18 05:19 PM
02/11/18 05:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
This, from my experience, Mopar and others. Always fixed by finding the fuel source. I've never used sealant on intake bolts.
Re: How does oil get here? [Re: furious70] #2450270
02/11/18 08:43 PM
02/11/18 08:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
NEVER !!! You pull out those bolts and you've got bits of that sh!t falling down into the engine.
Re: How does oil get here? [Re: furious70] #2450273
02/11/18 08:46 PM
02/11/18 08:46 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Stat-O-Seals to the rescue.
Re: How does oil get here? [Re: John_Kunkel] #2450298
02/11/18 09:35 PM
02/11/18 09:35 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Had the same problem on my 340. Tightened and sealed all the manifold bolts and it was still happening. Closer inspection I found the Fuel bowl gasket leaking on the holly carb. Rebuilt the carb and problem solved.
Re: How does oil get here? [Re: furious70] #2450688
02/12/18 03:10 PM
02/12/18 03:10 PM
IL
IL
ya, I think you guys are right about the gas. I see little stains all over the intake now. The carb had been gone through not that long ago but maybe our Chicago gas has killed it again. I hadn't put my fingers in the goo until yesterday, it's somewhat sticky, though it still does a pretty good job mimicking oil!
70 Sport Fury
68 Charger
69 Coronet
72 RR
