Damper removal HELP*^#!!!
#2449780
02/10/18 09:35 PM
02/10/18 09:35 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Hey guys, trying to remove a damper/harmonic balancer, have tried 3 different pullers and bent or broken everything, this thing is stuck on good. It is a Romac balancer on a close to new Scat crank. Any help or idea's welcome, wasted 4 hours on it yesterday its driving me nuts.
1963 Plymouth Max Wedge 1971 Barracuda
Re: Damper removal HELP*^#!!!
[Re: ozymaxwedge]
#2449845
02/10/18 11:10 PM
02/10/18 11:10 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
1) Your favorite penetrant, front and rear of the hub. 2) Your favorite puller (if any still remain) in firmly-moderate tension overnight. 3) A little more tension added in the morning along with a couple well-placed raps with a hammer and large pin on the hub at the crank. 4) Catch the damn damper.
Worked on a FD that refused to come off...
Old, tired, and sometimes broke down. Me, not my car...
[Re: ozymaxwedge]
#2449850
02/10/18 11:17 PM
02/10/18 11:17 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
How about pics of the puller you are using?
[Re: markz528]
#2449871
02/11/18 12:04 AM
02/11/18 12:04 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m betting you are using an 8.00 Harbor Freight pulley puller instead of a good harmonic balancer install, puller tool. Once you use one you won’t go back.
[Re: ozymaxwedge]
#2449959
02/11/18 05:49 AM
02/11/18 05:49 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Any feedback on the Jegs Universal remover/installer kit? http://www.jegs.com/i/JEGS-Performance-Products/555/W89711/10002/-1I bought one and it seems pretty nice, but I have not had to pull a really stuck damper with it? As Shoozy said, soak it, put tension on it, tap it a bit, and let it sit overnight. Then repeat. If your going to trash the damper, hit it with some good heat from a torch. On the aftermarket stuff (crank and/or damper), check the press fit of the damper to crank. According to my machine shop, it is fairly common to have to hone the damper a bit so it is not too tight? My ATI damper was honed at the machine shop to fit correctly. ATI says 0.002" for the aluminum hub units, and 0.0007" for steel. The Romac sheet on-line just notes 0.0005"?
[Re: AndyF]
#2449970
02/11/18 09:19 AM
02/11/18 09:19 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You need a real damper pulley like this one. I made this from heat treated steel that is 1 inch thick. Now that's a puller. Sell any?
[Re: pittsburghracer]
#2449981
02/11/18 11:12 AM
02/11/18 11:12 AM
ozymaxwedge
Australia
I’m betting you are using an 8.00 Harbor Freight pulley puller instead of a good harmonic balancer install, puller tool. Once you use one you won’t go back. That may be like the first one I broke but the next 2 pullers where 3/8 and 1/2 plate discs, only 3 bolt, bent them and snapped bolts. A genuine 8 hours work but we finally got it. I had a few old factory steel crank dampers so I cut the outer ring off, drilled out the 6 bolts, grabbed 6 x 5/16 ARP bolts and a mates power ram. Some serious metal transfer between the two surface, crank will need machining and I will be using a different damper. I'll post some pics tomorrow.
[Re: ozymaxwedge]
#2449982
02/11/18 11:13 AM
02/11/18 11:13 AM
ozymaxwedge
Australia
P.S, Andy's puller would normally do the job but there is not a hope in hell that it would have worked on this job.
[Re: ozymaxwedge]
#2449990
02/11/18 11:45 AM
02/11/18 11:45 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Trust me I have my share of cheap ones laying around. I finally had to buy one like the one in the Jegs link because I built a couple of Chevy engine and you can’t pull them on with the cheap azz bolt that GM uses to hold them on. It’s a very nice tool but it makes you stop and think and remember set up because it installs and removes. Do yourself a favor and use some anti-sieze on it when you put the next one on.
[Re: justinp61]
#2450345
02/11/18 10:45 PM
02/11/18 10:45 PM
RapidRobert
going back together (FWIW) would some heat on the dampener/dry ice on the snout help?
