How does oil get here?
#2449777
02/10/18 09:31 PM
02/10/18 09:31 PM
Posts: 2,255 IL
furious70
IL
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: How does oil get here?
[Re: Jim_Lusk]
#2449836
02/10/18 11:02 PM
02/10/18 11:02 PM
Posts: 1,250 North Carolina
469runner
North Carolina
If it's oil, it's likely coming up through the threads in the intake bolt. This. Seen it many times. Put some liquid thread sealant on intake bolts.
[Re: furious70]
#2449881
02/11/18 12:23 AM
02/11/18 12:23 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Looks like gasoline to me, and I see a trail leading down to it.
[Re: furious70]
#2450051
02/11/18 02:06 PM
02/11/18 02:06 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Been twisting wrenches for over 50 years, mostly on Mopars. this is typically oil following the intake bolt threads up and pooling in the intake. A little sealer on the intake bolts is all you need.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Tempest]
#2450170
02/11/18 05:19 PM
02/11/18 05:19 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
I had same thing and it was accelerator pump gasket on Holley. Looks just like oil after most of the gas evaporates. This, from my experience, Mopar and others. Always fixed by finding the fuel source. I've never used sealant on intake bolts.
[Re: furious70]
#2450270
02/11/18 08:43 PM
02/11/18 08:43 PM
Posts: 8,874 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I put some silicon on the threads. NEVER !!! You pull out those bolts and you've got bits of that sh!t falling down into the engine.
[Re: furious70]
#2450273
02/11/18 08:46 PM
02/11/18 08:46 PM
Posts: 25,827 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Stat-O-Seals to the rescue.
[Re: furious70]
#2450688
02/12/18 03:10 PM
02/12/18 03:10 PM
Posts: 2,255 IL
furious70
IL
ya, I think you guys are right about the gas. I see little stains all over the intake now. The carb had been gone through not that long ago but maybe our Chicago gas has killed it again. I hadn't put my fingers in the goo until yesterday, it's somewhat sticky, though it still does a pretty good job mimicking oil!
