Dry Sump Oil Tank mounting question... 40Ford??????
#244924
03/06/09 01:59 PM
03/06/09 01:59 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I was talking to one of the local circle track guys here and he told me the return line has to empty into the tank higher than the engine He didn't know why thats just what he was told. Can anyone explain this to me.
Re: Dry Sump Oil Tank mounting question... 40Ford??????
[Re: DemonDust]
#244925
03/06/09 05:43 PM
03/06/09 05:43 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
I have never heard that! I would just make sure Its higher than the pump!
[Re: boatracer572]
#244926
03/06/09 06:42 PM
03/06/09 06:42 PM
DemonDust
Menomonee Falls
Thats what I thought too.. Being higher than the engine makes no sense to me
[Re: 40ford]
#244931
03/07/09 11:41 AM
03/07/09 11:41 AM
Posts: 858 Oklahoma
silverfish
Oklahoma
Under normal conditions---you do not need to reprime the pump before startup. If we haven't started the engine for a week, we might spin the engine over for 15 seconds before turning on the ignition. If we haven't started the engine for 1 month, we probably would reprime.
Think about a dry sump system as two separate systems, the pressure system and the scavenge system. The scavenge system goes from the oil pan to the pump and into the top of the tank. There is no way for the oil to get from the tank back into the oil pan if it is plumbed correctly. The tank keeps the pressure section always primed---and there is no way that gravity can drain a tank UNLESS the tank is mounted well above the engine.
Thanks! I was wondering about just spinning the engine over like you say. Thats basically the same as spinning it over with a drill. Also, I'm glad you confirmed the drain back thing too. I thought the exact same thing when I was told the oil would run back into the pan. The only line coming out of the bottom of the tank is the suction line that goes to the pump. Thanks for the clarification.
[Re: 40ford]
#244932
03/07/09 11:58 AM
03/07/09 11:58 AM
DemonDust
Menomonee Falls
Great! Thanks for the all the info. I didn't want to burn anything up either. Pretty simple. I was wondering about turning the engine over with the ign off to prime it, if it sits for a while. Thanks again
[Re: silverfish]
#244933
03/07/09 11:59 AM
03/07/09 11:59 AM
boatracer572
San Jose Ca.
Peterson Fluid systems make nice drive nuts for the pump pulley to prime!I can remove the belt on the pump,and spin the pump by "hand" and see 40 psi!!
[Re: DemonDust]
#244936
03/07/09 07:27 PM
03/07/09 07:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
One more dumb question, can these pumps cavitate and lose their prime if there isn't any oil for them to pickup for a short time? Say on accel or decel?
Just curious, cause my block has a scavenge in the rear of the cam tunnel, but the cam tunnel has some holes drilled in it to drain to the oil pan. Should I run the pickup in the rear or just cap it off? Cause it may be just sucking air %80 of the time
As 40 said they do run some oil all the time but you have 2,3, or even 4 times the scavenge rate of the supply side... also this is the reason the dry sump creates a vac in the engine. With just the dry sump on my engine it creates 12" of hg in the higher revs
