18 spline input shaft diameter ?
#2447330
02/06/18 12:32 PM
02/06/18 12:32 PM
Posts: 19,380 north of coder
moparx
this is a really stupid question, so please, just consider it from my "old timers" diseased mind ! what is the spline diameter of the 18 spline shaft ? here is the reason for asking. sunday, a buddy showed up with a plastic pilot tool that had 18 splines. however, it was just a tick over 5/8" in diameter, and the pilot was only about 7/16". neither one of us has a transmission, but i said it looked way small, i "thought" it [the spline] should be closer to 1" or so ? i tried the google, but didn't have any luck. so, help this dum old guy out, please ? TIA as always !
Re: 18 spline input shaft diameter ?
[Re: moparx]
#2447519
02/06/18 06:34 PM
02/06/18 06:34 PM
Posts: 25,767 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The official input shaft spline dimension is 1-3/16 x 18T.
[Re: moparx]
#2447601
02/06/18 08:36 PM
02/06/18 08:36 PM
Posts: 350 Houston
it's Bob
Houston
HemiStan "missed it by that much"....Holding fingers 1/32" apart. Better than I could measure, probably.
[Re: it's Bob]
#2447647
02/06/18 09:38 PM
02/06/18 09:38 PM
dogdays
If the splines are the same diametral pitch then the diameter corresponds to number of splines linearly.
If, however, the diametral pitch is changed then you have things like the larger diameter shaft with fewer splines. A prime example of this is on GM and Ford input shafts. A common style is 10 splines. The Ford is 1 1/16" diameter, the GM is 1 1/8", and there are trucks with 10 splines with input shaft 1 3/8". Each example is using a different diametral pitch when they design the splines.
We're luckier when it comes to axles, because MOST of the popular axles use the same diametral pitch. So in general, we know that a 29 spline axle is stronger than a 27 spline and weaker than a 30. This is disregarding the strength of the axle material, of course. However the strength of the axle in torsion increases by the cube of the increase in diameter, so you can see that increasing from a 27 spline to a 31 spline increases strength by 51%.
Had enough?
R.
[Re: dogdays]
#2447679
02/06/18 10:09 PM
02/06/18 10:09 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
Had enough?
R. Or in other words....some of the Centerforce clutch kits & tools have 18 splines & come up in a search for "70 Road Runner" but are the wrong diameter... ask me how I know. Another thing to consider is that my eyes aren't good enough to determine the pitch of splines...so I just count them....stupid non-bionic eyes
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
