#2445486 - 02/03/18 12:30 AM Radiator hoses 69 B Body?
StukaJU87 Offline
Loc: Northern NJ
'69-383, b body, 26" radiator.
Want to buy new upper and lower hoses for the Bee.
Was looking at Rock Auto and have no idea what would be the best to buy for a driver car.
What make and part numbers are you guys using that are good quality and fitment?
Thanks in advance.
Scott
1969 Super Bee, 383/4 speed
#2445540 - 02/03/18 07:58 AM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
therocks Offline
Its Lost
Loc: Niles , Ohio
Last ones we got for my 65 and the 62 was at Advanced.IIRC they were stock gates.Ordered the 62s and they were there next day.Rocky
Chrysler Firepower
#2445612 - 02/03/18 10:31 AM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
gtx6970 Offline
Loc: It's a dry heat
Gates #20630 for the upper
Gates #20609 for the lower
#2445685 - 02/03/18 01:03 PM Re: Radiator hoses 69 B Body? [Re: gtx6970]
StukaJU87 Offline
Loc: Northern NJ
Thank you so much!
Scott
#2445693 - 02/03/18 01:20 PM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
StukaJU87 Offline
Loc: Northern NJ
One last thing, shouldn't the lower hose have that coil spring in it?
Is it in there? If not, what material are you using to make one?
Scott
#2445696 - 02/03/18 01:29 PM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
markz528 Offline
Loc: Milford, OH
I have never seen them come with a spring - I believe intent is to reuse the old one. I make mine out of stainless steel spring wire.
67 Coronet 500 (street car) 13.300 @ 101.75 mph
#2445697 - 02/03/18 01:32 PM Re: Radiator hoses 69 B Body? [Re: markz528]
StukaJU87 Offline
Loc: Northern NJ
Alrighty, thank you.
Scott
#2445764 - 02/03/18 03:28 PM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
sixbbl 69 Offline
Loc: Illinois
will these fit 69 440-6bbl cars?
#2445816 - 02/03/18 04:31 PM Re: Radiator hoses 69 B Body? [Re: sixbbl 69]
gtx6970 Offline
Yes.
#2445840 - 02/03/18 05:25 PM Re: Radiator hoses 69 B Body? [Re: gtx6970]
thehemikid Offline
Loc: ky hills
#2446014 - 02/03/18 10:52 PM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
parksr5 Offline
Loc: Oh
Has anyone used any brand of hose that was junk? I guess I've just never seen any hose (that was right for the application) that did not work regardless of brand name.
#2446151 - 02/04/18 09:40 AM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
moparx Offline
Dreaming of implants
Loc: north of coder
for springs, i have used .074dia. stainless wire and wrapped it around some black pipe [1" i think] that was a little smaller than the i.d. of the hose. since the pipe is smaller than the inside of the hose, it will spring back to the perfect diameter. make sure the ends are deburred and "pig tailed" so they don't contact the inside of the hose, then screwed into the hose. cheap [around $3.99 for a 30" piece of wire at the local ACE hardware] and easy to do.
beer
#2446172 - 02/04/18 10:11 AM Re: Radiator hoses 69 B Body? [Re: moparx]
StukaJU87 Offline
Loc: Northern NJ
beer
That's awesome, thank you for the tip!
Scott
#2446789 - 02/05/18 09:56 AM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
moparx Offline
Loc: north of coder
one thing i forgot to add that makes this work. drill a 3/32" [.0935] hole in the pipe, then insert the wire till it bottoms. this starts the "pig tail" and it keeps the wire from rolling around the pipe as it's wound up. practice using a coat hanger first to get a feel for this. if running a coolant with lube and anti corrosion inhibitors, you could even use the coat hanger if you wanted ! i prefer stainless though, just for peace of [my] mind.
beer
#2447282 - 02/06/18 03:23 AM Re: Radiator hoses 69 B Body? [Re: StukaJU87]
lemondana Offline
Loc: southeast NE
Rockauto, use Continental 60659 lower, 60621 upper. Continental bought out Goodyear industrial products. So the Continental products you now see were formally Goodyear..
The spring in the lower hose served only for the purpose of the vacuum fill on the assembly line. I've worked at this Goodyear plant for 30 years. Back when they made the big block hoses for instance. The original hose that went to the Chrysler factory had the springs in them, the replacement hoses that were sent to the dealers and the Goodyear brand were the same hose but NO spring was installed. If you need a spring then you have some other problem with your cooling system. YOU SHOULD NOT NEED A SPRING!
25,742 Registered Members
192,976 Topics
Who makes custom t shirts ?
by 420SIX
Today at 04:18 PM
USA source for German made tools
by 360view
Today at 03:42 PM
I like trains
by bigdad
Today at 03:17 PM
Fiddy Three Dodge w/ Hemi
by Neil
Today at 03:02 PM
