Re: where did you put your proportioning valve? [Re: lockjaw-express] #2447432
02/06/18 04:13 PM
02/06/18 04:13 PM
If the M.C. is above the highest point on the brakes like a stock Mopar has then the residual valve maintains pressures on the pads not letting them retract all the way, no need for the valve on disc. in my opinion work
I installed a SSBC front disc kit on my 1955 Dodge Coronet and used a later model Mopar brand aluminum dual piston M.C. for a later car that had disc brake application that I assumed that the residual valve was not there, it was and when I would push the car out of the shop into the sun the change in brake fluid temp. would make the car harder to push back, untightening the front brake line cured that when it burped fluid out of the fitting work shruggy
I'm building a 1940 Ford Tudor sedan with 4 wheel disc with the M.C. mounted under the floors and I used the Wilwood 3 lbs. residual valves in both lines to avoid allowing the fluid to drain back into the M.C. over filling it and making me have to pump the brakes to stop up
Re: where did you put your proportioning valve? [Re: J_BODY] #2447762
02/06/18 11:53 PM
02/06/18 11:53 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
My master is in stock location.... no residual valves added anywhere. This wasn't a post about aesthetics, but rather the theory of valve placement. Coming from a "regular" automotive background it's easy to say that you'd want the valve on the line to regulate the rear brakes as the fronts do most of the stopping.... HOWEVER, when you put "drag race" only and skinny little front runners into the equation it changes the story somewhat. Obviously no matter the tire size, you don't want too much rear bias (good way to find yourself suddenly staring at the starting line at trap speed), but you do have a lot more meat out back with the slicks to help slow things down.
Another chapter in things you notice when you go faster.
Jay "slo-kid"
Re: where did you put your proportioning valve? [Re: J_BODY] #2447766
02/06/18 11:58 PM
02/06/18 11:58 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Threw it out....Neither of my cars has one....
Re: where did you put your proportioning valve? [Re: Dragula] #2447781
02/07/18 12:10 AM
02/07/18 12:10 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
never ever? all in know is that with Wilwood/drum combo and "nothing" I'm eating up real estate getting my junk stopped, and my 3rd set of front rotors should be here tomorrow.
The thought crossed my mind to simply install the rear discs (Strange) and see how things go, but I'll most likely throw the valve on.
Re: where did you put your proportioning valve? [Re: J_BODY] #2447858
02/07/18 02:52 AM
02/07/18 02:52 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
In a box on the garage shelf. Bias seems good with Wilwood 4 wheel disc on my junk. I would try it first.
"Just a Bracket car dressed up like a streetcar"
Re: where did you put your proportioning valve? [Re: J_BODY] #2447898
02/07/18 08:20 AM
02/07/18 08:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mark Williams recommends panic stopping on a slippery surface at low speed to test brake bias. Will this replicate real conditions? Don't Know. What I do know is you don't want to panic stop one day and find out the rears skid instead of the fronts, don't ask how I know. Most drag cars will skid the fronts with no valve do to tire size bias. But if all 4 skid together or the front just slightly earlier it'll stop straight.
Doug
Re: where did you put your proportioning valve? [Re: J_BODY] #2447902
02/07/18 08:43 AM
02/07/18 08:43 AM
Dragula Offline
Dragula  Offline
Both cars are big tires pro-street types with Willwoods on all four corners....My chassis guy said to throw it out...So I did...That was many years ago...Sure simplifies the Line Line plumbing.
Re: where did you put your proportioning valve? [Re: Dragula] #2447917
02/07/18 10:53 AM
02/07/18 10:53 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I was told also to leave it out. Strange brakes all around.
Re: where did you put your proportioning valve? [Re: J_BODY] #2447922
02/07/18 11:11 AM
02/07/18 11:11 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Can't say that I don't agree with the "splice just makes one more place to leak" theory laugh2
I've read the MW manifesto Doug. That was linked on another rear brake discussion quite awhile back. I "kind of" thought the rear drums should work for my deal, but like I stated earlier, since getting the W8 mill running we've been killing front rotors a lot sooner than I prefer. I was also a little leary of the "skid test" you noted, although it probably falls into the better than nothing bin.
I'm running the Wilwood 150-8850K pads
"Wilwood Smart Pad BP-10 brake pads feature a medium-friction compound with the low noise and low dust of a street performance compound, plus the increased friction characteristics of a semi-metallic race compound. They have smooth engagement, with consistent response from a flat torque curve throughout their entire effective temperature range. These pads have good low-to-middle temperature wear rates and they bed quickly and provide a fast response without excessive abrasion on vented iron rotors. They are ideal for a variety of high performance street/strip, drag race, and track-day categories using vented iron rotors. They also provide light-to-medium braking on dirt tracks, including late models, Modifieds, sportsman, and street stocks"
my new front rotors (solid, not slotted) should be here today, and I stock pads for them now (another lesson learned) so maybe we'll try it without the valve and see how it goes.
Re: where did you put your proportioning valve? [Re: J_BODY] #2447986
02/07/18 01:29 PM
02/07/18 01:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
With the correct pedal ratio and master cylinder you should not need an adjustable proportioning valve. I have not had one on a car in YEARS. To include the RJ car in the garage with Carbon Brakes.
IMO the Wilwood pads are part of the issue IMO. We switched to Hawk pads and have never looked back.
Re: where did you put your proportioning valve? [Re: J_BODY] #2448008
02/07/18 02:19 PM
02/07/18 02:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree may/may not need one. But cheap and easy to do during the build. Not so much after its all laid out and done.
Doug
Re: where did you put your proportioning valve? [Re: Al_Alguire] #2448009
02/07/18 02:20 PM
02/07/18 02:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have Wilwood Dynalite on the rears and 11" Mopar brakes on the front with a Strange "mopar style" master and mine stops smooth and easy with no drama without a valve of any kind twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: where did you put your proportioning valve? [Re: J_BODY] #2448012
02/07/18 02:28 PM
02/07/18 02:28 PM
AndyF Offline
AndyF  Offline
Setting up a brake system is actually a complex engineering problem. Many bracket racers approach it by randomly buying parts out of a catalog and then they have issues. There is a lot more stuff written on how to pick a cam than there is on how to pick a brake system which is probably a mistake.
For starters the fronts usually do twice the work of the rears so you need twice as much brake force up front as at the rear. That means the front pistons need to be twice the area of the rear pistons if the rotors are the same diameter.
If the front tire is too small to handle the brake force then you end up with a different problem. Trying to stop the car with the rear brakes is very tricky. The car is a lot more stable if most of the brake force is coming from the front tires.
Killing front rotors sounds like a pad issue to me but maybe the rotors are undersize. You might not have a brake balance problem, you might just have a component issue.
The best way to debug brake problems is to put a pressure gauge in both the front and the rear brake lines. Once you know what the pressure is in the lines then you can debug the rest of the issue. For really tricky problems you can use a heat gun or temp paint to figure out if the rotors are overheating.
Re: where did you put your proportioning valve? [Re: J_BODY] #2448020
02/07/18 02:40 PM
02/07/18 02:40 PM
AndyF Offline
AndyF  Offline
Also, a disc drum type of car requires a prop valve since drum brakes are non-linear and disc brakes are linear. So you need a prop valve to "blow off" the excess pressure to the drum brakes or else they'll always lock up.
A 4 wheel disc car does not need a prop valve if the caliper piston size is correctly matched. The piston ratio front to rear depends on the weight distribution of the car as well as the height of the center of gravity. Basically what you are trying to do is to match the brake force with the weight on the wheels. So a nose heavy car needs more front brake force than a car with a 50/50 weight distribution. And a car that is jacked up in the air transfers more weight to the front during a stop than a car that is super low to the ground.
A good chassis should be around 50/50 weight distribution and low weight transfer to the front and would need 2x the brake force up front than in the rear. So the area of the front caliper pistons needs to be 2x the area of the rear caliper pistons. If you follow that forumula you should be in the ball park. You can tune it with the pad selection. If it is way off then you need to adjust the line pressure or the piston size or the rotor diameter.
It isn't black magic, just regular old engineering calculation. Randomly selecting brake parts out of a catalog won't work any better than randomly selecting pistons and camshafts will work when building an engine.
Re: where did you put your proportioning valve? [Re: AndyF] #2448031
02/07/18 03:16 PM
02/07/18 03:16 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Jay the big tires go in the back.. laugh2... I do not have a valve on my car...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: where did you put your proportioning valve? [Re: Just-a-dart] #2448053
02/07/18 03:51 PM
02/07/18 03:51 PM
gregsdart Online content
gregsdart  Online Content
Same brakes, same results.
Re: where did you put your proportioning valve? [Re: J_BODY] #2448092
02/07/18 05:27 PM
02/07/18 05:27 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
So...some think it goes on the front, some think it goes on the rear, some are having trouble stopping their car and want to reduce braking one end or the other to fix it.
Big tires on the back, skinnies up front, you can't have the fronts doing the majority of the work. That will wreck you.
How many door cars are out there with 2 little calipers up front and 4 four piston calipers on back? They aren't out there spinning around in circles in the lights.
Which port of your MC delivers the highest volume or are they equal? You need to know.
I've seen Wilwood calipers that look like other company's parts, but the bores are substantially smaller. They will not work the same. What size are the bores of your calipers?
