TorqStorm superchargers #2446596
02/05/18 12:16 AM
02/05/18 12:16 AM
Wisconsin
T-Fish Offline OP
T-Fish  Offline OP
Wisconsin
Does anyone on here have any firsthand experience with them? I’ve searched the internet and found a couple of articles on them. I’ve seen nothing bad and I’ve seen some skepticism from others that haven’t heard of them. What I haven’t seen is dyno numbers, with the exception of one small block Chevy.
Re: TorqStorm superchargers [Re: T-Fish] #2446599
02/05/18 12:22 AM
02/05/18 12:22 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Go to a Goodguys event if you can. Torquestorm is always there and I usually see several cars there with torquestorm superchargers.
Re: TorqStorm superchargers [Re: T-Fish] #2446704
02/05/18 04:42 AM
02/05/18 04:42 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Couple of my buddies have bought kits, but no installs yet. Blower is supposed to make about 9 psi IIRC.
Re: TorqStorm superchargers [Re: T-Fish] #2446830
02/05/18 01:50 PM
02/05/18 01:50 PM
michigan
Jeff@torqstorm Offline
michigan
We have several mopar kits out there. We dont always get results back from our customers. But, one of our customers has a 340 dart that made 600 hp at 6.5#.
Here is the article
http://www.hotrod.com/articles/supercharged-small-block-1970-dodge-dart/
Re: TorqStorm superchargers [Re: Jeff@torqstorm] #2448302
02/08/18 01:29 AM
02/08/18 01:29 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here is the article
Interesting, and that's with a tiny hydraulic cam. A little more motor and a little more boost could make a fun street combo.
Re: TorqStorm superchargers [Re: T-Fish] #2450180
02/11/18 05:56 PM
02/11/18 05:56 PM
K
Kiddart Offline
Kiddart  Offline
K
I stopped in to Torque storm last summer in grand rapids Michigan. I had a bunch of questions and they answered all of them gave me a tour and really spent quality time with me. I am almost done with the new motor and when that's done I will be buying one of these as of right now. He also mentioned if you really wanted they can put a different size pulley to increase the boost.
Awesome shop and awesome guys.
Thank you
Kiddart
Re: TorqStorm superchargers [Re: T-Fish] #2450182
02/11/18 05:58 PM
02/11/18 05:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Have a friend with one on a Gen3 hemi. Runs strong.
Re: TorqStorm superchargers [Re: T-Fish] #2450445
02/12/18 12:58 AM
02/12/18 12:58 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
can these be intercooler? I see no reason why not, just wondering if they have done it.
Re: TorqStorm superchargers [Re: 8urvette] #2450457
02/12/18 01:25 AM
02/12/18 01:25 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Yes.......
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: TorqStorm superchargers [Re: T-Fish] #2450532
02/12/18 05:25 AM
02/12/18 05:25 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How much HP/air/boost can these things make? looking at the kit for the 03-08 Ram with 5.7
Re: TorqStorm superchargers [Re: T-Fish] #2483357
04/15/18 11:04 PM
04/15/18 11:04 PM
San Diego
JP8 Offline
JP8  Offline
San Diego
Although some manufacturers claim a specific horsepower increase, superchargers actually add horsepower as a percentage gain (percentage of an atmosphere). Assuming an engine with a compression ratio of around 9:1 running pump gas,if a supercharger gives your engine 14.7 psi of boost (another atmosphere) that will essentially double the output of your engine, everything else being equal. After adjusting for thermal and mechanical energy transfer, if an efficient centrifugal supercharger is generating 7.5 psi (approx. 1/2 an atmosphere), you will see around a 35-40% gain in horsepower and torque at your non-supercharged maximum horsepower rpm. If detonation forces you to use an ignition/timing retard system, you will of course see less of a gain because backing off several degrees of timing will greatly reduce an engine's power output. At higher boost levels, the heat generated by compressing air will produce diminishing returns as the boost is increased, although the use of intercooling or racing fuel can avoid this scenario of diminishing returns. Assuming the use of intercooling to run higher boost levels while maintaining reliability, a 100% increase can generally be achieved at around 17 psi on an engine with 9:1 compression running pump gas.
https://www.procharger.com/how-much-horsepower-will-supercharger-add-my-engine
I was looking at the Torqstorm kit for 225 /6. That would be fun in an early A! Prices look better than Procharger too.
Instagram : @5_points_racing
Re: TorqStorm superchargers [Re: T-Fish] #2483432
04/16/18 01:52 AM
04/16/18 01:52 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Way too much of that written by the sales department.
"superchargers actually add horsepower as a percentage gain (percentage of an atmosphere)"
Except for the power lost in the drive, pumping loss, and heat expansion of the charge.
"if a supercharger gives your engine 14.7 psi of boost (another atmosphere) that will essentially double the output of your engine"
This never happens.
If you're actually interested: http://victorylibrary.com/mopar/blower/blower.htm
Boffin Emeritus
Re: TorqStorm superchargers [Re: polyspheric] #2485446
04/20/18 04:39 AM
04/20/18 04:39 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
This never happens.
i'll give you that. While there have been engine builds that have superchargers doubling the output they are a special set of circumstances with well planned high dollar builds. You shouldn't think that by just adding a supercharger you can double the output. An instance like that would be a very specific and expensive combination that would not last long in a higher mileage engine. Best you can, or should hope for, is a more realistic 25% -30% if you expect it to last in real world driving. Yes, factor in parasitic loss and heat and detonation mitigation efforts which will bring that 50% down in a hurry.
Re: TorqStorm superchargers [Re: T-Fish] #2485447
04/20/18 04:43 AM
04/20/18 04:43 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I did it with a turbo. 😛
Re: TorqStorm superchargers [Re: T-Fish] #2485478
04/20/18 09:31 AM
04/20/18 09:31 AM
London, England
Gavin Offline
Gavin  Offline
London, England
To be fair, although they maybe could have worded it more clearly, that quote is saying that in theory doubling the pressure doubles the horsepower, but in practice it will actually be less and they explain why...I don't see them claiming that in the real world this will actually happen - in fact they say exactly what will be more likely.
Re: TorqStorm superchargers [Re: T-Fish] #2485533
04/20/18 12:00 PM
04/20/18 12:00 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This was known to conflict with thermodynamic laws 100 years ago.
Boffin Emeritus
Re: TorqStorm superchargers [Re: T-Fish] #2485988
04/21/18 10:32 AM
04/21/18 10:32 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Yes, I'm not arguing that and did not write the article..I'm just saying that as I read it it was trying to move from the simple and understandable notion that that if you put in twice the air and fuel you'd expect the power to double, to the more accurate and technical representation which is that due to losses etc, you don't actually get that.
Feel free to read it differently, as I said they could have worded it better, it did not come across to me as stating a scientific fact, which is supported by the fact they immediately contradict it....YMMV
Re: TorqStorm superchargers [Re: T-Fish] #2486042
04/21/18 01:14 PM
04/21/18 01:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It came across as a sales pitch that they misrepresented as science.
At the pressures you're going to see, an Eaton (somewhat better than GMC, worse than Autorotor) may reach 70% efficiency: the gauge shows 10 psi, but the actual change mass is not (10 + 14.7) ÷ 14.7 = +68%, but ((10 × .70) + 14.7) ÷ 14.7 = +48%. Then subtract blower drive loss...
Boffin Emeritus
Re: TorqStorm superchargers [Re: polyspheric] #2486143
04/21/18 05:58 PM
04/21/18 05:58 PM
The last 10:71 super charged street hemi motor I built and dyno tested made 924 HP at 7300 RPM with 7.0 Lbs. of boost, we swapped the pulleys to go from 13% under driven to 12% over driven which ended up making 12.0 Lbs. at 6500 RPM and 1027 HP before going into detonation whiney
That was not quite doubling the pressure by over driving that 10:71, the manifold inlet temps go up any time you compress air more, hot air expands also so the resistance to the rotors compressing air goes up also robbing power from the motor to drive the super charger work
I remember one of the NHRA T.V. announcers commenting several years ago that the top fuel blowers take over a 1000 HP to drive them shruggy
Re: TorqStorm superchargers [Re: T-Fish] #2486190
04/21/18 09:29 PM
04/21/18 09:29 PM
New York
polyspheric Offline
polyspheric  Offline
New York
One thing that makes the math not quite intuitive is the fact that no engine has zero vacuum @ WOT (the usual Holley formula produces 1.5" vacuum), so 5 psi boost is actually a 5.73 psi improvement (compared to NA).
Roots etc. which add fuel at the top (not Eaton which is EFI as OEM) also cool the charge as it vaporizes, no effective prediction on density. Even this is complicated:
1. very fine fuel atomization (annular venturis, big mains, big HSAB) cools most, but gas vapor displaces air mass. Also makes bigger explosions if you hang an exhaust valve!
2. large fuel droplets cool less, but subtract much less from air mass
How to tell which? Listen to your engine builder, or do A > B.
Boffin Emeritus
