Cam/rocker questions #2446399
02/04/18 06:49 PM
02/04/18 06:49 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Does changing the rocker ratio(from 1.5 to 1.7) change anything else other than lift?
Thanks, Brian
Re: Cam/rocker questions [Re: '72CudaRacer] #2446407
02/04/18 06:56 PM
02/04/18 06:56 PM
It changes the lift and duration from .005 and upwards on any camshaft work up scope
I now check the lift on the lobes and then again on the retainers with soft checking springs to verify the ratio on all the after market rockers I buy and use now up scope
You may find out that not all rocker ratio are accurate puke shock runaway scope
