Radiator hoses 69 B Body?
#2445486
02/03/18 03:30 AM
02/03/18 03:30 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
'69-383, b body, 26" radiator.
Want to buy new upper and lower hoses for the Bee.
Was looking at Rock Auto and have no idea what would be the best to buy for a driver car.
What make and part numbers are you guys using that are good quality and fitment?
Thanks in advance.
Scott
1969 Super Bee, 383/4 speed
Re: Radiator hoses 69 B Body?
[Re: StukaJU87]
#2445540
02/03/18 10:58 AM
02/03/18 10:58 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Last ones we got for my 65 and the 62 was at Advanced.IIRC they were stock gates.Ordered the 62s and they were there next day.Rocky
Chrysler Firepower
[Re: gtx6970]
#2445685
02/03/18 04:03 PM
02/03/18 04:03 PM
StukaJU87
Northern NJ
Gates #20630 for the upper Gates #20609 for the lower Thank you so much!
Scott
[Re: StukaJU87]
#2445693
02/03/18 04:20 PM
02/03/18 04:20 PM
StukaJU87
Northern NJ
One last thing, shouldn't the lower hose have that coil spring in it? Is it in there? If not, what material are you using to make one?
Scott
[Re: StukaJU87]
#2445696
02/03/18 04:29 PM
02/03/18 04:29 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
One last thing, shouldn't the lower hose have that coil spring in it? Is it in there? If not, what material are you using to make one? I have never seen them come with a spring - I believe intent is to reuse the old one. I make mine out of stainless steel spring wire.
[Re: markz528]
#2445697
02/03/18 04:32 PM
02/03/18 04:32 PM
StukaJU87
Northern NJ
One last thing, shouldn't the lower hose have that coil spring in it? Is it in there? If not, what material are you using to make one? I have never seen them come with a spring - I believe intent is to reuse the old one. I make mine out of stainless steel spring wire. Alrighty, thank you.
Scott
[Re: moparx]
#2446172
02/04/18 01:11 PM
02/04/18 01:11 PM
StukaJU87
Northern NJ
for springs, i have used .074dia. stainless wire and wrapped it around some black pipe [1" i think] that was a little smaller than the i.d. of the hose. since the pipe is smaller than the inside of the hose, it will spring back to the perfect diameter. make sure the ends are deburred and "pig tailed" so they don't contact the inside of the hose, then screwed into the hose. cheap [around $3.99 for a 30" piece of wire at the local ACE hardware] and easy to do. That's awesome, thank you for the tip!
Scott
