Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445080
02/02/18 07:15 AM
02/02/18 07:15 AM
Ca
76440 Offline OP
76440  Offline OP
Ca
Found another 727 front band listed with more pictures.
http://transmissiontechnologies.com/Band...odge-62-UP.aspx
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445133
02/02/18 12:07 PM
02/02/18 12:07 PM
A727Tflite Offline
A727Tflite  Offline
Sorry - forgot you are working on a 42 . They don't use the lug. The adjustment screw rides against the band where the missing piece is, it pilots between the two vertical fingers.
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445140
02/02/18 12:23 PM
02/02/18 12:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What tears that ear off? I've torn two off on my A998's.
Don't be the exception.
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445221
02/02/18 03:26 PM
02/02/18 03:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
got to pull the trans to swap that one, I did a stock band replace in a 46re one time but there is no way no how the stock band is going out or in with the trans assembled and I have searched many times for a slip in band and never found one for the smaller 904 based trannys
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: Supercuda] #2445239
02/02/18 03:57 PM
02/02/18 03:57 PM
A727Tflite Offline
A727Tflite  Offline
On the 904/998/999/42/44 series units the failure usually comes from a band adjustment that gets out of whack and you start loading one of the vertical fingers instead Of the center lug of the band. Then all the load goes in to the finger which is designed to be a guide and not a load carrying member. If you look at this failed band you will notice the one vertical finger is bent and weld is broken and a piece of the band is missing.
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445247
02/02/18 04:18 PM
02/02/18 04:18 PM
Ca
76440 Offline OP
76440  Offline OP
Ca
I called that place that has the 727 / 46RE front slip-in band listed. He says he sells a good number of those but he does not know of a 904 42RE slip-in band being made.
Looks like I have to pull the trans unless someone has an idea for sneaking a band in while the trans is installed. Or a source for a slip-in 904/ 42RE front band?
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445321
02/02/18 06:54 PM
02/02/18 06:54 PM
A727Tflite Offline
A727Tflite  Offline
You can try and see if you can snake your old parts out - backwards - remove the one with the damaged end first - then see if you can push the other around and out - that will tell you if the spot welded end will fit between the case and the front clutch drum. If it does then you should be able to install the new band. Whichever end is shorter on the new band is the end you want to install first.
I think the small boxes are a little tighter inside.
Good luck.
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445447
02/03/18 01:17 AM
02/03/18 01:17 AM
Guitar Jones Offline
I've tried before and I'm pretty persistent. Couldn't do it.
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2445453
02/03/18 01:45 AM
02/03/18 01:45 AM
A727Tflite Offline
A727Tflite  Offline
Maybe your parts were swollen from being down by the river shruggy work
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: A727Tflite] #2446080
02/04/18 05:51 AM
02/04/18 05:51 AM
Ca
76440 Offline OP
76440  Offline OP
Ca
Was not able to get the kickdown band out with the trans in the car.
Pulled the trans out and planning to install a new band. Then put the trans back in the jeep without doing a overhaul. Hopefully not a big mistake but the jeep needs to get back together asap.
Should I change the front pump seal or since it was not leaking it should be okay?
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2446123
02/04/18 11:58 AM
02/04/18 11:58 AM
A727Tflite Offline
A727Tflite  Offline
I'd leave well enough alone if the converter was dry.
New pump to case gasket and that's it.
Unless you see more issues when you get it apart. Keep track of the thrust washers and be careful putting the pump back in so you don't damage the reaction shaft to front clutch seal rings.
It helps most people to stand the trans up to install the pump - that's how the plant did it too.
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: A727Tflite] #2446133
02/04/18 12:14 PM
02/04/18 12:14 PM
At least I don't have rusty swollen nuts. laugh2
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: Guitar Jones] #2446161
02/04/18 12:55 PM
02/04/18 12:55 PM
moparx Offline
moparx  Offline
hmmm........ not sure i want to know. but with "film at 11", it just might be humorous. biggrin
beer
Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0 [Re: 76440] #2446227
02/04/18 02:37 PM
02/04/18 02:37 PM
A727Tflite Offline
A727Tflite  Offline
Good to know ( I think ) that you don't have rusty swollen nuts. 👀
