Re: 42RE Trans? 2004 Jeep Grand Cherokee 4.0
[Re: 76440]
#2445080
02/02/18 07:15 AM
02/02/18 07:15 AM
Posts: 762 Ca
76440
Ca
[Re: 76440]
#2445140
02/02/18 12:23 PM
02/02/18 12:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What tears that ear off? I've torn two off on my A998's.
[Re: 76440]
#2445221
02/02/18 03:26 PM
02/02/18 03:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
got to pull the trans to swap that one, I did a stock band replace in a 46re one time but there is no way no how the stock band is going out or in with the trans assembled and I have searched many times for a slip in band and never found one for the smaller 904 based trannys
[Re: Supercuda]
#2445239
02/02/18 03:57 PM
02/02/18 03:57 PM
Posts: 3,081 Michigan
A727Tflite
What tears that ear off? I've torn two off on my A998's. On the 904/998/999/42/44 series units the failure usually comes from a band adjustment that gets out of whack and you start loading one of the vertical fingers instead Of the center lug of the band. Then all the load goes in to the finger which is designed to be a guide and not a load carrying member. If you look at this failed band you will notice the one vertical finger is bent and weld is broken and a piece of the band is missing.
[Re: 76440]
#2445447
02/03/18 01:17 AM
02/03/18 01:17 AM
Guitar Jones
I've tried before and I'm pretty persistent. Couldn't do it.
[Re: 76440]
#2446123
02/04/18 11:58 AM
02/04/18 11:58 AM
A727Tflite
I'd leave well enough alone if the converter was dry. New pump to case gasket and that's it.
Unless you see more issues when you get it apart. Keep track of the thrust washers and be careful putting the pump back in so you don't damage the reaction shaft to front clutch seal rings.
It helps most people to stand the trans up to install the pump - that's how the plant did it too.
[Re: A727Tflite]
#2446133
02/04/18 12:14 PM
02/04/18 12:14 PM
Guitar Jones
Maybe your parts were swollen from being down by the river At least I don't have rusty swollen nuts.
