Balancing question for engine builders in here? #244364
03/05/09 08:15 PM
03/05/09 08:15 PM
South Carolina
a408swinger Offline OP
mopar addict
mopar addict
South Carolina
I freshened up my motor this winter and bought 8 new pistons. I also went from a set of hand ported 360-1's to a set of 245cc CNC 360-1's which have a 2.15 intake valve instead of a 2.10 so the only changes I had them make in the pistons was to make them for a 4.045 bore instead of a 4.040 bore and to cut the valve relief for the bigger 2.15 intake valve. The pistons are Ross and they also made my last set. I also had them make the pistons the same weight as my old ones so I didn't have to re-balance my rotating assembly. After getting the new pistons and assembling my motor I had piston to valve clearance problems. After calling Ross they realized they cut the valve reliefs too small and I had to pull the motor back apart and send them the pistons back so they could fly cut the reliefs the right size. Now the pistons are 9 grams lighter than my old ones. They are telling me its no problem and I dont need to re-balance my motor. Is this true? Is 9-10 grams not too light? They are telling me its not a problem for the pistons to be lighter. I turn this motor over 7500 rpm's. What should I do?
Re: Balancing question for engine builders in here? [Re: a408swinger] #244365
03/05/09 08:58 PM
03/05/09 08:58 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
They are correct! All you have is a very slight "overbalance" due to the lighter pistons. You didn't say what your bobweight is---probably in the 1600-1700 gram range. This 9 grams would be only 1/2% overbalance. Many high RPM engines use 1,2 or even 2 1/2% overbalance. Some shops overbalance 1% for everything but street engines.
What you don't want is an "underbalance" situation.
Re: Balancing question for engine builders in here? [Re: 40ford] #244366
03/05/09 09:18 PM
03/05/09 09:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I dont remember the exact numbers but engine builder/tester David Vizard did some testing with overbalancing and found out there was free HP to be had. I think he found like 15 free HP by adding a slight overbalance on a 350 chevy. So like stated above mike
Re: Balancing question for engine builders in here? [Re: a408swinger] #244367
03/06/09 05:15 AM
03/06/09 05:15 AM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Has anyone actually checked weights of the pistons to see how close the shop has actually balanced them to "0" ? ....or whatever the shop claimes ?
A Bud of mine checked a well-known shop in the Detroit area ..... they claimed they balanced to 2 tenths. He weighed the pistons and some were off by almost 5 grams.
But some people claim that with all the oil flying around and on the rotating-assembly ....up to 10 grams off really does not matter.
Re: Balancing question for engine builders in here? [Re: dOc …] #244368
03/06/09 06:13 AM
03/06/09 06:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chrysler was the worst of the big 3 when it came to
balance on the factory stock engines. Sure they will
stay together but I'm a big believer in a good balance
specially if you take it up in the revs. For you
to feel it in the seat of your pants... its got to
be BAD
Re: Balancing question for engine builders in here? [Re: Sport440] #244369
08/16/09 12:43 AM
08/16/09 12:43 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Found it for you RP, mike
Re: Balancing question for engine builders in here? [Re: Sport440] #244370
08/16/09 10:27 AM
08/16/09 10:27 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Thanks Mike
My engine is only 2% overbalance. 1528 g assembly and 1567 bobweight on my crank.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Balancing question for engine builders in here? [Re: a408swinger] #244371
08/16/09 10:52 AM
08/16/09 10:52 AM
NC
440Jim Offline
440Jim  Offline
NC
Don't stick those pistons in your engine, tell Ross to stick them...
You ordered a certain weight and valve relief size, don't pay for anything less.
If it is "OK" or not is not the right question. You didn't get what you ordered. Plain and simple. If you are thinking of accepting the pistons, ask for the cost of rebalancing the crank, plus shipping and handling... LOL
Re: Balancing question for engine builders in here? [Re: dOc …] #244372
08/16/09 10:56 AM
08/16/09 10:56 AM
NC
440Jim Offline
440Jim  Offline
NC
I check them before and after they balance them. My scale isn't as good as a good balance shop, but my measurements showed they all matched within the amount I can "read" on my scale (not claiming 1g accuracy).
Re: Balancing question for engine builders in here? [Re: 440Jim] #244373
08/16/09 08:15 PM
08/16/09 08:15 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Jim , what does the shop that you use, "as a rule of thumb" balance thier cranks to or otherwise thier accepted standard perimeters in reguards to 50%/even or 50%+ overbalance. 51% being equal to a 1% over balance. mike
