Re: Guys with Bridgeports at Home
[Re: STEFF]
#2442431
01/28/18 08:45 PM
01/28/18 08:45 PM
Posts: 2,175 Duloc
The Shadow
Duloc
[Re: STEFF]
#2442443
01/28/18 09:04 PM
01/28/18 09:04 PM
Posts: 4,274 Morrow, OH
markz528
Morrow, OH
Hands down - VFD. You want the variable speed and the braking capability of the VFD.
Foe mine, I replaced the original 1 hp motor with a 3 hp aluminum frame motor. I think I paid around $250 for the motor. I went with the 3 hp to make up for lost torque because I went with a single pulley - this way no more changing belt position to get a wide range of speed. Leave it in a high speed position and use the VFD to lower the speed.
You have a few options for braking with a VFD. The best solution is to use a dynamic braking resistor. I use DC injection - not as good but is decent and easier to implement.
Don't plan on listening to AM radio when the VFD is on................
[Re: PC-CHARGER]
#2442451
01/28/18 09:14 PM
01/28/18 09:14 PM
markz528
Morrow, OH
VFD but it must connect directly to the motor, no contacters.
That's not really true. If the drive is closely rated to the motor size, then the drive will trip on over-current if you close the contactor when the drive is on. If the drive is oversized, then closing the contactor while the drive is on won't hurt a thing. Neither the motor or drive would care, but in a single motor application like this it does not make sense to do this. For example, my surface grinder spindle is a 1 hp motor. The coolant pump is 1/6 hp. I run both off of a single 1 hp drive (I don't exceed the drive rated amps). I slam the coolant pump on/off at will with a contactor when the drive is running the spindle. Works absolutely fine. The trick is the drive must be able to provide the inrush current and the drive needs to be set up in volts/hertz mode. For a mill you prefer sensorless vector mode because you don't lose torque at low speeds like you do in volts/hertz mode. No issues if you don't run in volts/hertz mode at low speeds. My mill is volts/hertz (so old it don't have sensorless vector mode) and I can stall the motor at very low speeds.
[Re: STEFF]
#2442460
01/28/18 09:24 PM
01/28/18 09:24 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Changed the motor to single phase.
[Re: STEFF]
#2442462
01/28/18 09:25 PM
01/28/18 09:25 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
I built a rotary phase converter for under $20 using cast off parts that I scrounged: a 5 horse 3 phase motor for the converter, a 1/2 horse 110 motor to start the converter motor spinning, and then bought 2 pulleys and a belt to connect them.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: STEFF]
#2442463
01/28/18 09:28 PM
01/28/18 09:28 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I’ve used the phase-a-matic converters in the past. I would get 2 to 3 years out of them. Fixed one a few times. Finally went with a rotary phase converter. Machines run much smoother, and reversing on demand works perfectly. No comparison between the two on performance.
[Re: STEFF]
#2442514
01/28/18 10:39 PM
01/28/18 10:39 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I use a static converter on my Bridgeport. No issues.
I use a rotary on my CNC.
[Re: STEFF]
#2442525
01/28/18 11:06 PM
01/28/18 11:06 PM
markz528
Morrow, OH
A little bit of rewiring and Steff will be fine! A little birdie told me.............
[Re: STEFF]
#2442573
01/29/18 12:22 AM
01/29/18 12:22 AM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
I want one so BAD, hate to hijack but, I have a 50 hp Roto-Phase converter for my other 3 ph machines, so am I good to go? You guys are talking way over my head. PS. I want one I can put an engine block in.
[Re: STEFF]
#2442588
01/29/18 12:42 AM
01/29/18 12:42 AM
Posts: 4,569 Motor City
6PKRTSE
Motor City
We have 12 of bridgeport and other brand Mills at work. I can use any of them when I need to but I still want one for at home someday along with a nice lathe.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: cudaman1969]
#2442642
01/29/18 01:42 AM
01/29/18 01:42 AM
FastmOp
Hot Rod Ridge
I want one so BAD, hate to hijack but, I have a 50 hp Roto-Phase converter for my other 3 ph machines, so am I good to go? You guys are talking way over my head. PS. I want one I can put an engine block in. Your good to go for anything with a motor size up to 25 HP
