Re: Setting up an aftermarket AMP gauge?
[Re: wally426ci]
#2439977
01/24/18 01:11 PM
01/24/18 01:11 PM
RapidRobert
As you know you want it in series to show ALL current flowing to/from the battery with the exception of the large wire on the starter. You would want it added into the main power wire coming thru the fusible link/past the bulkhead before that wire T's into seperate circuits (fuse/headlights/ign sw etc).
[Re: wally426ci]
#2439979
01/24/18 01:16 PM
01/24/18 01:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Can it be done? Yes.
Is there an aftermarket setup for vehicles that can do it? Not that I know of.
You'd need a current transformer setup to do what you want. Ever see those meters with the clamp you put around a wire to measure current flow? Something like that is what you'd need.
[Re: wally426ci]
#2440038
01/24/18 02:48 PM
01/24/18 02:48 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
https://www.amazon.com/Search-Analog-Amm...nt+less+ammeterI thought about adding a shunt-less analog gauge like the above to my older battery charger that only has an analog voltage gauge. A 0-60 or 0-100 amp full scale gauge would be preferable. Simply running a loop of heavy gauge wire from the battery connection into the cab and back would allow clipping a Hall Effect amp metter on and reading amps. I have had a 0-300 ac/dc Fluke Hall Effect clip on probe as an accessory for my Fluke 87 multimeter that has worked well for a couple decades now. It actually has wires long enough to stretch from the battery to the cab of the truck. There are also shunt meters: https://www.amazon.com/MICTUNING-6-5-100...+volt+amp+meter
[Re: wally426ci]
#2440043
01/24/18 02:57 PM
01/24/18 02:57 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
there are aftermarket and performanced full amp load ammeters in the market.
but why don't get an used replacement amm gauge for the cluster like it was and aftermarket underdash voltmeter ?
trust me, you don't need more than 40 amps gauge in dash... and if you do, something is wrongly hooked up. A discharged batt will never get more than 40 amps to be recharged. Chemicals are not that fast.
And if it does, something else is wrong, aside a fully discharged batt never must be charged back on car... not at least taking care of some other stuff
[Re: wally426ci]
#2440047
01/24/18 03:07 PM
01/24/18 03:07 PM
NachoRT74
Valencia, España
you can also rebuilt your stock cluster gauge using a factory 60 amps unit and install the ammeter face from your D100
https://www.ebay.com/itm/1971-Plymouth-GTX-Roadrunner-Dodge-Charger-Super-Bee-NOS-MOPAR-Ammeter-Amp-Gauge/330851585796?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
althought can't recall if the D100 cluster is with needle pointing up or down. studs gap uses to be the same in all Mopar ammeters
then install an underdash voltimeter
[Re: wally426ci]
#2440049
01/24/18 03:10 PM
01/24/18 03:10 PM
NachoRT74
Valencia, España
or maybe this, 50 amps:
https://www.ebay.com/itm/1951-1952-Plymouth-NOS-MOPAR-Ammeter-Amp-Gauge/253258728043?hash=item3af765826b:g:bLgAAOSwyWZZWaoJ&vxp=mtr
[Re: wally426ci]
#2440050
01/24/18 03:12 PM
01/24/18 03:12 PM
NachoRT74
Valencia, España
here is one 80 amps
https://www.ebay.com/itm/NOS-Mopar-1972-1974-B-Body-ammeter-gauge-3592133-w-o-rallye/370842976147?epid=1217906272&hash=item5657f6bf93:g:P~0AAOxyfS1Ryyef&vxp=mtr
but everyone by now ith needle pointing up
[Re: wally426ci]
#2440051
01/24/18 03:14 PM
01/24/18 03:14 PM
NachoRT74
Valencia, España
it seems you can get 50 amps for your truck ?
https://www.ebay.com/itm/NOS-MOPAR-1962-1963-1964-1965-1966-1967-1968-1969-DODGE-TRUCK-AMMETER-GAUGE/262419279071?epid=1329984388&hash=item3d19686cdf:g:QZoAAOSwS7hXAToY&vxp=mtr
I reafirm you don't need more than 50 amps in dash, since the batt will never suck that load to be recharged. Chemicals doesn't work so fast
[Re: wally426ci]
#2440053
01/24/18 03:18 PM
01/24/18 03:18 PM
NachoRT74
Valencia, España
os this one... also listed for 68 truck ?
https://www.ebay.com/itm/NOS-MoPar-1961-1968-Dodge-D-W100-Truck-AMMETER-GAUGE-pn-1936914-2906072/332237625334?hash=item4d5ae7d7f6:m:mB0adFIq-jZjMsAOGn73PYA&vxp=mtr
50 amps, and needle pointing down
[Re: wally426ci]
#2440054
01/24/18 03:19 PM
01/24/18 03:19 PM
NachoRT74
Valencia, España
60 amps pointing up
https://www.ebay.com/itm/NOS-Mopar-1968-1970-Plymouth-Dodge-B-Body-Models-60-Amp-Ammeter-PN-2857005/272933360973?hash=item3f8c18954d:g:k68AAOSwxp9W4Gj~&vxp=mtr
[Re: wally426ci]
#2440057
01/24/18 03:21 PM
01/24/18 03:21 PM
NachoRT74
Valencia, España
NOS stock 68 truck... I guess 40 amps
https://www.ebay.com/itm/Mopar-NOS-1961-68-Dodge-Truck-Ammeter-Gauge-Instrument-Panel-Type-SA2-2906072/222222405458?hash=item33bd7ccf52:g:i~cAAOSwZVlXtJLK&vxp=mtr
[Re: wally426ci]
#2440058
01/24/18 03:21 PM
01/24/18 03:21 PM
NachoRT74
Valencia, España
and cheap aftermarket option, 60 amps
https://www.ebay.com/itm/Isspro-Ammeter-Gauge-2-1-4-2-round-0-30-60-Ford-Mopar-Chevy-Camaro-Old-Amp/372185409521?hash=item56a7faa7f1:g:9vwAAOSwYXVYz3k-&vxp=mtr
[Re: wally426ci]
#2440059
01/24/18 03:23 PM
01/24/18 03:23 PM
NachoRT74
Valencia, España
Cheap NOS from whatever car... 50 amps
https://www.ebay.com/itm/Mopar-NOS-Ammeter-Gauge-Markd-21259/152739801553?epid=1173302429&hash=item23900069d1:g:y6EAAOSwzJ5XWx1W&vxp=mtr
once again, to become it on the cluster replacement gauge reinstalling your original gauge face
[Re: wally426ci]
#2440061
01/24/18 03:24 PM
01/24/18 03:24 PM
NachoRT74
Valencia, España
and another NOS 50 amps unit
https://www.ebay.com/itm/NOS-MOPAR-DODGE-TRUCK-AMMETER-ASSY-2958549/183033742226?epid=1017921174&hash=item2a9da94392:g:ItIAAOSwKu9TxdSK&vxp=mtr
well... there are options
[Re: 360view]
#2440196
01/24/18 07:47 PM
01/24/18 07:47 PM
Supercuda
About to go away
About to go away
up yours
That is essentially the stock setup, but without the ability to read discharge current Using a shunt could do the trick, if he put's it at the starter relay connection As for all the OE type replacements suggested, don't bother to comprehend the question, ok?
[Re: wally426ci]
#2440619
01/25/18 04:40 PM
01/25/18 04:40 PM
NachoRT74
Valencia, España
depending on how did you modify the stock underdash harness to feed the voltmeter and bypass the cluster ammeter system, will rule what would you need to rewire that into the aftermarket ammeter. And that's something what only you know.
the deal is you can splice any wire coming from alt splice down the dash harness to the ammeter, but the wire to the batt MUST BE just one, the one coming out from + lead of ammeter to batt/starter relay stud. You can't get other one but that one between ammeter and batt.
In other words you can even run a straight wire between alt post and ammeter keeping the existant wires from the alt side in place BUT YOU CAN'T run the same between ammeter and batt. All the batt side of the wiring MUST GO THROUGHT the ammeter
