Pushrod Holes in Magnum Heads #2439784
01/23/18 11:10 PM
01/23/18 11:10 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Does anyone have a guide or pictures of how to go about clearancing the push-rod holes on magnum heads to accommodate use on an LA block with flat-tappet cam?
Re: Pushrod Holes in Magnum Heads [Re: jeebis44] #2439811
01/24/18 12:38 AM
01/24/18 12:38 AM
I would mockup with some light springs & just eyeball how much clearance you have like in Joesixpacks' nearby thread then dremel em out as needed. set the heads down easy on the head gaskets & barely snug each head with several head bolts & mockup the valvetrain & turn the crank over with a 1&1/4" socket/breaker bar.
Re: Pushrod Holes in Magnum Heads [Re: jeebis44] #2439812
01/24/18 12:38 AM
01/24/18 12:38 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have never had to clearance them, done a bunch and even with one like an R/T head with a machined hole never had to clearance one.
Re: Pushrod Holes in Magnum Heads [Re: jeebis44] #2440189
01/24/18 07:16 PM
01/24/18 07:16 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Wasn't there a magnum head template floating around between the forum users to drill this out?
1972 Dodge Challenger
Re: Pushrod Holes in Magnum Heads [Re: jeebis44] #2440351
01/25/18 01:49 AM
01/25/18 01:49 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the template is for porting, there was a jig for doing the intake bolt holes, I never had an issue with PR clearance but I have also never tried to run them with anything bigger diameter than a stock one. If there is an issue it can't be much just mark it and grind it a bit with a dremmel.
Re: Pushrod Holes in Magnum Heads [Re: jeebis44] #2440363
01/25/18 02:13 AM
01/25/18 02:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Been my observation that roller heads have bigger pushrod holes than flat tappet heads so I wonder why you'd need to open up the magnums?
Don't be the exception.
