Re: Bearing clearance w/ alum rods?
[Re: '72CudaRacer]
#2438501
01/21/18 05:42 PM
01/21/18 05:42 PM
Posts: 4,457 Washington
madscientist
Washington
Aluminum rods get smaller with every heat cycle. Did you measure the rod bore? I'd bet it's under where you started.
Knock the pins out. Home the rods to size and go.
[Re: '72CudaRacer]
#2438603
01/21/18 08:33 PM
01/21/18 08:33 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
.0035-.0040" is where I would aim, with an edge to the larger end of the scale.
